1949 M-47 Dash questions
Old Jul 16, 2017 | 07:13 PM
way2rod's Avatar
way2rod
Hi Hope you all have had a great weekend!
As some of you know I just got this truck with a bunch of boxes of parts, everything stripped down by the previous owner..... so I'm not really sure on a few things....Now I'm working on the wiring I have a few questions..... Any help would be appreciated.
Zac
1) I have 2 instrument clusters 1 is just the standard one you see everywhere and then there is this one. Do you know what it's out of? Mercury? Canada?
Here's a picture.....
2) In one of the boxes there is a lighter. Did these trucks come with one? If so where was it located? It looks the same as heater controles and choke ****.
Thanks again
Old Jul 16, 2017 | 08:41 PM
56panelford's Avatar
56panelford
If it was a Mercury it wouldn't have said Ford on it, my guess..
Old Jul 16, 2017 | 08:58 PM
Mixer man's Avatar
Mixer man
The cross-hatching is missing from that instrument cluster face so someone has been in there, but the gauges and speedo needle look authentic. I think someone made an overlay for the speedo face.
If you look closely you will see a flat spot on the dash just under the ash tray - that's where the lighter goes.
Old Jul 16, 2017 | 09:05 PM
schoo's Avatar
schoo
Here is a pic of Marks speedo restored no Ford
48 F3
Old Jul 16, 2017 | 10:03 PM
Mixer man's Avatar
Mixer man
Restored gauge cluster.
Old Jul 17, 2017 | 03:19 AM
matthewq4b's Avatar
matthewq4b
I suspect it is from a Mil application. The flat black painting of the instrument cluster plate sort of gives it away as a Mil application. The Canadian military in the era was using mostly Fords for COTS vehicles. I have seen other Milcots Fords from the era with unique bits. The Canadian Military even had a hand full of Ford trucks converted to half tracks to use as artillery tractors.
Old Jul 17, 2017 | 06:32 AM
way2rod's Avatar
way2rod
Thank you everyone for all your responses you guys are awesome!!!
Old Jul 17, 2017 | 06:33 AM
way2rod's Avatar
way2rod
Military would never have thought of that but it makes sense. There's a good size base here in town. It really looks like it was done like that right from the factory I've looked close and I can't see any marks around the trim ring..... like scratches on the tabs for the bezel that would indicate someone was in there at a later time.
Thanks
Zac
Old Jul 17, 2017 | 06:55 AM
way2rod's Avatar
way2rod
Was the lighter in a hole under the ash tray or hanging?? I don't see a hole there. Also was this something that was added after would they drill the dash? I have a hole just to the right of my cluster and left of radio grill.... looks like the size of the lighter once the case is unscrewed.
Thanks
Zac
Old Jul 17, 2017 | 07:09 AM
FortyNiner's Avatar
FortyNiner
Thanks
Zac
By your description, that should be the location of the ignition switch.
Old Jul 17, 2017 | 07:17 AM
way2rod's Avatar
way2rod
At the expense of tiring out you all from answering questions..... I have another one....
Re: Heater. I have the 3 door heater with the reversing motor for defrost. I know I need to replace the motor since I'm going 12v but what do you think of using the original switch? And if so does anyone know how it was wired it looks like 4 wires and a resistor on the back but I didn't think these old trucks had a fan speed control.... just on and off. Here's a picture of the back...
Also what is this.... 1 wire **** missing
Thanks again..... appreciate any help
Zac
Old Jul 17, 2017 | 07:20 AM
way2rod's Avatar
way2rod
Sorry should have clarified.... The hole is near the top of the cluster not along the bottom. I'd post a picture but I'm nowhere near the shop now.
Thanks
Zac
Old Jul 17, 2017 | 01:58 PM
Mixer man's Avatar
Mixer man
Thanks
Zac
The lighter was a factory option, but they were also installed by the dealers. The flat spot on the dash curvature is very subtle, but that's where it goes. You will have to make your own hole. I recommend using a 3/4" hole punch instead of a drill, but make sure to measure first. Aftermarket clamp-on lighters were also available at the time.
Old Jul 17, 2017 | 05:14 PM
way2rod's Avatar
way2rod
That's great I will check that out tonight.... thanks for the info.
Zac
Old Jul 17, 2017 | 05:43 PM
Mixer man's Avatar
Mixer man
You can just barely make out the flat spot in these pics.
Cab interior is cleaning up nice.
Zac
