1949 M-47 Dash questions
Hi Hope you all have had a great weekend!
As some of you know I just got this truck with a bunch of boxes of parts, everything stripped down by the previous owner..... so I'm not really sure on a few things....Now I'm working on the wiring I have a few questions..... Any help would be appreciated. Zac 1) I have 2 instrument clusters 1 is just the standard one you see everywhere and then there is this one. Do you know what it's out of? Mercury? Canada? Here's a picture..... https://cimg7.ibsrv.net/gimg/www.for...56d40cf8d3.jpg 2) In one of the boxes there is a lighter. Did these trucks come with one? If so where was it located? It looks the same as heater controles and choke knob. Here's a picture..... https://cimg0.ibsrv.net/gimg/www.for...ff743e13af.jpg https://cimg1.ibsrv.net/gimg/www.for...8b69eeb7ec.jpg Thanks again |
If it was a Mercury it wouldn't have said Ford on it, my guess..
The cross-hatching is missing from that instrument cluster face so someone has been in there, but the gauges and speedo needle look authentic. I think someone made an overlay for the speedo face.
If you look closely you will see a flat spot on the dash just under the ash tray - that's where the lighter goes. |
Here is a pic of Marks speedo restored no Ford
https://cimg7.ibsrv.net/gimg/www.for...130e184468.jpg 48 F3 |
https://cimg0.ibsrv.net/gimg/www.for...8c0ec81a55.jpg
Restored gauge cluster. |
I suspect it is from a Mil application. The flat black painting of the instrument cluster plate sort of gives it away as a Mil application. The Canadian military in the era was using mostly Fords for COTS vehicles. I have seen other Milcots Fords from the era with unique bits. The Canadian Military even had a hand full of Ford trucks converted to half tracks to use as artillery tractors.
Thank you everyone for all your responses you guys are awesome!!!
Originally Posted by matthewq4b
(Post 17333424)
Thanks Zac |
Originally Posted by Mixer man
(Post 17332948)
Thanks Zac |
Originally Posted by way2rod
(Post 17333571)
I have a hole just to the right of my cluster and left of radio grill.... looks like the size of the lighter once the case is unscrewed.
Thanks Zac |
At the expense of tiring out you all from answering questions..... I have another one....
Re: Heater. I have the 3 door heater with the reversing motor for defrost. I know I need to replace the motor since I'm going 12v but what do you think of using the original switch? And if so does anyone know how it was wired it looks like 4 wires and a resistor on the back but I didn't think these old trucks had a fan speed control.... just on and off. Here's a picture of the back... https://cimg6.ibsrv.net/gimg/www.for...694bc80d9f.jpg Also what is this.... 1 wire knob missing https://cimg2.ibsrv.net/gimg/www.for...6ba87055be.jpg Thanks again..... appreciate any help Zac |
Originally Posted by FortyNiner
(Post 17333609)
By your description, that should be the location of the ignition switch.
Thanks Zac |
(Post 17333571)
Was the lighter in a hole under the ash tray or hanging?? I don't see a hole there. Also was this something that was added after would they drill the dash? I have a hole just to the right of my cluster and left of radio grill.... looks like the size of the lighter once the case is unscrewed.
Thanks Zac |
(Post 17334619)
The lighter was a factory option, but they were also installed by the dealers. The flat spot on the dash curvature is very subtle, but that's where it goes. You will have to make your own hole. I recommend using a 3/4" hole punch instead of a drill, but make sure to measure first. Aftermarket clamp-on lighters were also available at the time.
Zac |
You can just barely make out the flat spot in these pics.
https://cimg9.ibsrv.net/gimg/www.for...679a0ce4e2.jpg https://cimg0.ibsrv.net/gimg/www.for...fbbc49bb80.jpg https://cimg5.ibsrv.net/gimg/www.for...2690020196.jpg Cab interior is cleaning up nice.
(Post 17335008)
That's great I will check that out tonight.... thanks for the info.
Zac |
