bad gas mileage on my expedition
Old Jul 15, 2017 | 05:37 PM
andrew871's Avatar
andrew871
im having a problem with getting the correct gas mileage on my expedition like when i go to put gas in it will say i have 200 miles to empty but after driving a few miles it will drop to 180 for some reason.... other times when i take it for a drive i look at my miles to empty and compare it to miles driven they do not match for example i had 200 miles to empty but after 10 miles it says it took like 17 miles off to empty so im not getting the correct driven miles to miles to empty dont match up so what is causing this problem i have changed the oil and filter added marvel mystery oil put seafoam into gas tank and even used throttle bottle spray so im not sure what else i can do to fix this problem
Old Jul 16, 2017 | 09:04 AM
alloro's Avatar
alloro
The DTE number is calculated based on your average MPG and the amount of fuel left in the tank. As your average MPG changes or if fuel sloshing around in the tank is causing the float to rise and lower to often, then the DTE will be constantly changing.
If your average MPG is rather constant, then the issue is with the fuel level sender and has nothing to do with how the engine is running.
Old Jul 16, 2017 | 09:51 AM
andrew871's Avatar
andrew871
I dont understand I mean why does the miles to empty tell me 200 miles to E but after driving say 10 miles it drops to 180 thats a loss of almost 10 miles of gas somewhere im not getting the correct miles driven to miles empty ratio... My truck use to get like 400 miles off of full tank of gas now it gets to empty around 250 miles
Old Jul 16, 2017 | 12:11 PM
alloro's Avatar
alloro
What does the computer say your average MPG is?
Old Jul 16, 2017 | 12:33 PM
andrew871's Avatar
andrew871
about 14 mpg
Old Jul 16, 2017 | 01:27 PM
alloro's Avatar
alloro
14 MPG with a 30 gallon tank (14x30=420).
If you're only seeing about 250 on a tank, then I would say your fuel gauge is reading empty when you still have about 1/2 a tank. This will also mess with the DTE reading.
Old Jul 16, 2017 | 01:35 PM
andrew871's Avatar
andrew871
yea but its not only the DTE thats reading miles to empty fast but gas gauge hand goes down fast as well im not getting the full 420 miles of a tank the gas hand is on E when there is about 250 still in gas tank
Old Jul 16, 2017 | 09:34 PM
Sterling6.7's Avatar
Sterling6.7
I would suggest that you start hand calculating the mileage to see what the real issue is. Bad mileage or bad sender.
Old Jul 18, 2017 | 09:36 AM
alloro's Avatar
alloro
Which goes right back to what I said about the fuel level sender being faulty. Like Sterling6.7 just said, switch to manual calculations and see what you get.
Old Oct 16, 2017 | 09:26 PM
andrew871's Avatar
andrew871
Do you think changing out the fuel pump will fix this problem
Old Oct 17, 2017 | 08:27 AM
rla2005's Avatar
rla2005
Have you calculated your true MPGs manually as previously suggested?
Araltd
15
Nov 15, 2011 09:49 PM
640 CI Aluminum FORD
2009 - 2014 F150
Jul 7, 2011 07:19 PM
EstevanKingRanch
58
May 28, 2008 11:02 PM
Slammer12
Escape & Escape Hybrid
33
Feb 18, 2005 09:19 AM
PrPlayboy
Jan 17, 2004 12:12 PM
