1947 Pickup 6 cylinder battery bracket needed
Old Jun 15, 2017 | 11:59 AM
triumph1200's Avatar
triumph1200
Fixing more little things. Need a bracket for a 47 6 cylinder G 1/2 ton. None of the suppliers I have called can help. Looking for NOS, used, repop doesn't matter. Part number is 2GC 10732. Anybody have one for sale or know a vendor that might have one?
Thanks in advance to all that reply
Old Jun 16, 2017 | 08:57 AM
tacomacream's Avatar
tacomacream
There is one here:
Take Off Vintage 1946 Ford F100 Battery Tray in Good Shape | eBay
Old Jun 16, 2017 | 09:23 AM
triumph1200
Originally Posted by tacomacream
Thanks for spotting it. I missed that one, probably because it had F100 in the title. Do you know how to tell if it is a 6cyl or V8 tray? Sent the seller a message hopefully they know.
Old Jun 16, 2017 | 10:02 AM
tacomacream
They are the same; the bracket is mounted on the left side for the six cylinder.
Old Jun 16, 2017 | 01:04 PM
46fordtruck's Avatar
46fordtruck
They are different. This weekend I will post pictures of the difference between a 6 cylinder and 8 cylinder battery tray.
The tray only has one stud, the other side doesn't have it, use the j-hook with the top brackets. On the 6 the stud is on opposite side than the 8 tray. I have 5 or 6 8 trays and one 6 tray in storage, I'll show the difference between them this weekend.
Old Jun 17, 2017 | 04:21 PM
Rust Wrangler's Avatar
Rust Wrangler
I believe the V8 bracket can be used in place of the six cylinder one by relocating the top tray. The V8 tray would be backwards mounted on the right side. The tray uses a small reinforcement bracket that attaches near the top of the long battery clamp rod and to the firewall, so the clamp rod needs to be closest to the firewall to make it right in the six cylinder position. I'd modify a V8 bracket without hesitation, as the six cylinder brackets are tough to find and in either case the top trays are usually rotted and need work anyway.
Old Jun 28, 2017 | 06:06 PM
triumph1200
After a couple of dead ends I decided to have the local welding shop repair it. $50.00 and I have a usable tray. Thanks for everyone's input
Old Jun 28, 2017 | 06:28 PM
Rust Wrangler
Glad you got it sorted out. Fifty dollars for making it whole again seems like a very fair price to me. I have one that I'll be using on my truck, so I was able to compare it to a V8 version. Looks like the top trays are just orientated different between the two for the most part.
obscurity
16
Aug 30, 2014 03:29 PM
ksmith203
Mar 3, 2013 01:49 PM
dhagert
13
Nov 10, 2008 05:18 PM
fyrmn681
Escape & Escape Hybrid
Jan 14, 2008 11:45 AM
ilovecrashing00
Nov 23, 2006 02:26 PM
