30k miles on this melted piston
Old Jun 14, 2017 | 12:36 AM
chetspencer's Avatar
chetspencer
So I finally found the problem with cylinder number 8 30k mile surviver
And this may have caused it
WTF this fell out of #8 exhaust port
The good news is the cylinder wall is in excellent shape. No scratches, but it's polished to a near mirror finish. I hope I can hone it back to like new condition so it matches all the other cylinders.
Old Jun 14, 2017 | 04:22 AM
Yahiko's Avatar
Yahiko
WOW looks a little chewed up in there.
If the taper and the bore is not out of round then you might make it.
Your going to need some "T" gauges of a bore gauge to tell for sure.
This is for the 2005 Excursion limited 4X4 6.0L?
Old Jun 14, 2017 | 05:34 AM
TooManyToys.'s Avatar
TooManyToys.
Missing tips off the GP or injector, or are they damaged?
Old Jun 14, 2017 | 06:43 AM
chetspencer
Yes, hopefully I will have my Excursion back on the road soon, glow plug and injector are not damaged. The valve faces are intact but I think the intake valves are bent as the related pushrod was slightly bent. I had the intake off before the melt down when I did a BPegr and standpipe upgrade so perhaps it's a bolt or previous owner part.
Old Jun 14, 2017 | 09:58 AM
DarkStarMedia's Avatar
DarkStarMedia
that kinda looks like the head of a pushrod.
Richard
Old Jun 14, 2017 | 10:03 AM
TooManyToys.
That's what I thought too based on what appears to be a hole on the left, but it's only a one dimentional view.
Old Jun 14, 2017 | 02:25 PM
chetspencer
The mystery piece is magnetic, anyways for future reference if anyone finds themselves in a similar situation, I unplugged the injector and drove it this way for years, even passed two smog checks.
Old Jun 14, 2017 | 08:01 PM
Per4mance's Avatar
Per4mance
I remember that when I first came on board and though I had a bad vacuum leak.
Old Jun 14, 2017 | 08:11 PM
chetspencer
I just remembered to ask you guys your opinion on using the #8 injector in my new engine. It's literally been just sitting there doing nothing since I installed it. Initially I was hoping it was a bad injector so I changed all 4 on that side way back when it **** the bed. I've ran out of dough to buy a new set of injectors so I'm planning on re oringing mine.
Old Jun 14, 2017 | 08:57 PM
Per4mance's Avatar
Per4mance
How's the tip look? Ohm it out and check the numbers. I'd move it to#2 for easier removal if it turns up lame.
Old Jun 14, 2017 | 09:00 PM
wedge542's Avatar
wedge542
Luck has been with you now this long with that piston and still driving it so maybe that number 8 inj will play along too, i dont see how it didnt hammer the tip off with that cold hard alum pieces flying around in it.
Old Jun 15, 2017 | 12:22 AM
chetspencer
The tip looks fine, and so does the injector tip from my new donor engine that also had a melted piston and a melted exhaust valve. Being the injectors are dead center in the chamber seems to be the reason for their surviving the carnage.
Old Jun 15, 2017 | 02:18 AM
Yahiko's Avatar
Yahiko
All it would take is one hit to make a crack that your not going
to be able to see with the eye. Then if it is cracked later down
the road the tip finally fails and starts dumping fuel. Bad Day.
If it were me I think at the least I would replace the nozzle
with a fresh stock one or go with a reman injector. Not worth
an engine over $206. Cheap insurance.
Old Jun 15, 2017 | 05:54 AM
Apocalypse's Avatar
Apocalypse
Obligatory "That'll buff out" joke.
cleatus12r
23
Jun 23, 2019 03:14 PM
c0rn_d0g
Mar 24, 2019 06:39 PM
mharneyva
May 4, 2017 03:56 PM
Fordenthusiasts
23
Sep 6, 2015 11:23 PM
whybnormal
Oct 18, 2007 07:58 AM
