Oldie but Goodie but won't stay running
Old Jun 3, 2017 | 04:36 PM
jacknewt's Avatar
jacknewt
87 Ford F150 4.9l -- Cycle key 5 times will start then runs out of gas unless you pump the pedal engine will go up and down. New parts put on this truck are new fuel tank, new fuel pump in tank, new fuel filter, new fuel pump on rail, new fuel pressure regulator, new tps sensor, new computer, new fuel injectors. Any suggestions.
Old Jun 3, 2017 | 04:55 PM
'89F2urd's Avatar
'89F2urd
Codes. Fuel pressure. Report back.
Old Jun 3, 2017 | 11:08 PM
jacknewt's Avatar
jacknewt
Codes that came up are 22, 34,67,81. Fuel pressure was 42
Old Jun 4, 2017 | 07:38 AM
FuzzFace2's Avatar
FuzzFace2
The 42 is that when you first turn the key on?
What if you try and start / run the motor does it stay at 42?
Dave ----
Old Jun 4, 2017 | 08:57 AM
jacknewt's Avatar
jacknewt
Went out this morning turned key on got 40 cranked it didn't get much more. Started it with gas got 42. Yesterday blocked return line and got 70 psi at rail and still did not start.
Old Jun 4, 2017 | 10:07 AM
'89F2urd's Avatar
'89F2urd
These things will start with very little fuel pressure, they just won't go anywhere without stalling.
I'd focus on the map sensor code, a faulty map will prevent it from running. Do you have a donor map to swap in? Parts truck or a friend? Junkyard?
Check vac line running to map also.
Old Jun 4, 2017 | 11:40 AM
jacknewt's Avatar
jacknewt
Thanks for reply. I ordered a map sensor on line should have it tomorrow. Will replace it and let you know what happens.
Old Jun 10, 2017 | 09:54 AM
jacknewt's Avatar
jacknewt
Finally, got it running. After replacing all the new parts, the last part replaced was the map sensor and it stayed running. Thanks for all the info from everyone. Greatly appreciated.
Old Jun 10, 2017 | 01:00 PM
'89F2urd's Avatar
'89F2urd
Good to hear. Don't go throwing parts at it next time! Save your old parts for spares.
parcher440
Oct 5, 2016 12:32 AM
matt2fan
Jul 10, 2012 03:13 PM
SMiddleton
Jul 1, 2011 03:34 PM
bjohndev6789
1983 - 2012 Ranger & B-Series
Aug 9, 2005 08:28 PM
slammed96
Oct 7, 2003 09:26 PM
