1990 302 water pump bolts
Old Jun 3, 2017 | 01:34 PM
dev-pow's Avatar
dev-pow
Hi my water pump was leaking in my 1990 302 f150 4x4 so i began the process of replacing it. While removing it 4 of the 7 bolts snapped off. i. Finally got them out after a week of wd-40 and propane torching it. but the bolts are... rough... Rough enough that i can tell what the lengths are. any of y'all know what size bolts i need for it? I'm thank full for any and all help
Old Jun 3, 2017 | 02:07 PM
KULTULZ's Avatar
KULTULZ
Post
The easiest way out of this (IMO) is to go to your dealer parts room, have them print off an illustration of the pump install and you circle the hardware you need.
Do you really want to replace the hardened cap-screws with HOME DEPOT CHI-COM Specials?
Old Jun 3, 2017 | 09:09 PM
wtroger's Avatar
wtroger
Dorman makes a kit the will get you most of them. The originals are just grade 5 bolts. So your hardware store does have them. Originals have captured washers you will have to add washers. Coat them in anti-seize head thru thread. They hang up due to corrosion around the shank.
Old Jun 3, 2017 | 09:15 PM
dev-pow's Avatar
dev-pow
Yeah i got the dorman for the studs. but how long are the bolts?
Old Jun 3, 2017 | 10:33 PM
Scndsin's Avatar
Scndsin
These are the dimensions I came up with:
https://www.ford-trucks.com/forums/1...ns-inside.html
Old Jun 6, 2017 | 11:50 PM
dev-pow's Avatar
dev-pow
thought i replied to you but i guess i didn't
but your info was super helpful. I'll be installing them Thursday after my new paint dries
Old Jun 7, 2017 | 07:34 AM
Scndsin's Avatar
Scndsin
Not a problem. Glad it helped.
Jmudweiser
25
Sep 17, 2018 02:13 PM
wtroger
Dec 22, 2016 11:59 AM
Lynn Nichols Adams
Mar 27, 2015 10:22 PM
tradecki
Feb 25, 2007 09:46 AM
Big Ol Truck
1978 - 1996 Big Bronco
Apr 28, 2004 10:32 AM
