67 F100 Front Brake Fit Problem
Old Apr 2, 2017 | 02:19 PM
69-er's Avatar
69-er
I have new front brake hoses that will not fit. The brake cylinder end just touches the king pin enough where it will not thread in. The fittings on the old ones, factory I assume, are just a little smaller in diameter and about 1/4" or so longer.
I've tried BrakeBest, #BH49927 and Duralast #88423. Next up will be NAPA #UP 36531 and Carquest/Advance #BHA4992.
Anybody have a good part# that will work?
Thanks!
Old Apr 2, 2017 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967 F100 Front Brake Hose Fit Problem
2WD or 4WD?
Old Apr 2, 2017 | 04:00 PM
69-er's Avatar
69-er
Sorry, 2WD!
Old Apr 2, 2017 | 04:06 PM
NumberDummy
1967 F100 2WD Front Brake Hoses
C5TZ-2078-A .. Front Brake Hose - 17 3/4" long; R/L is the same / Obsolete
1965/71 F100/250 2WD; 1967/71 F350.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
NOS PARTS LTD in Waxahachie TX has 16 = 972-937-2201.
Old Apr 2, 2017 | 04:11 PM
69-er's Avatar
69-er
Thanks Bill. I guess I can assume the typical parts store don't have the proper specs on this hose.
I'll give them a try!
Old Apr 3, 2017 | 07:58 PM
69-er's Avatar
69-er
Just discovered that while the larger diameter fitting of the new hose doesn't help, it's the brake cylinders that are causing the problem. The angle of the fitting hole is at an angle that moves the hose fitting closer to the king pin.
Now I need to find a correctly made cylinder. Right now NAPA is my only hope. Everyone else in town either doesn't carry it, the fitting angle is wrong or the bleed screw is pointing straight at the king pin and not angled away from it.
Sigh...
Old Apr 3, 2017 | 11:40 PM
GaryKip's Avatar
GaryKip
You are aware that the wheel cylinders are SIDE specific.
Old Apr 4, 2017 | 05:55 PM
69-er's Avatar
69-er
Absolutely. We're talking an error of a couple degrees. The hose fitting will almost thread in but its cocked a very small amount, enough to cross thread if continued. It's that close to clearing the king pin.
Old Apr 4, 2017 | 06:44 PM
69-er's Avatar
69-er
The NAPA cylinders did the trick! You can see in the first pic how close things are with the new hose and cylinder. The other shows the improved clearance due to the factory hose fitting's smaller diameter and longer length. With the last new cylinders I tried the fitting was moved to the right towards and beyond the king pin.
The part #'s of the NAPA cylinders are 37083 and 37084
Old Apr 4, 2017 | 06:45 PM
NumberDummy
CougarJohn
Jul 9, 2017 12:04 PM
mbrowne
Dec 17, 2016 03:56 PM
Ezridr65
Jul 11, 2015 04:11 AM
eyesie
Jun 30, 2011 03:44 PM
Hamburgerfella
Apr 19, 2011 10:16 AM
