Single side glass
Old Mar 7, 2017 | 11:29 PM
EBEAR's Avatar
EBEAR
Single side glass
I haven't got to this part of my build yet but I am confused on why there is single side glass kits for flat or curved glass , Does my 53 not have flat glass and if so how is curved going to work ?
Old Mar 8, 2017 | 06:09 AM
jniolon's Avatar
jniolon
old and in the way
Ebear,
original had flat glass with the vent window.. but the vent window was at a slightly different angle because of the door shape
if you go with one piece window you need curved glass to fit the door.. or you will have to modify the opening in the door sill.
john
Old Mar 8, 2017 | 12:38 PM
EBEAR's Avatar
EBEAR
OK that makes sense thanks . Do you know of any threads showing the process of modifying the doors ?
Old Mar 8, 2017 | 01:45 PM
CharlieLed's Avatar
CharlieLed
I do not have any in-process pics but here are a couple pics of the last flat glass mod I did. It is a simple process, remove the vent assembly and the window fuzzies, lay the new straight angle pieces on the door window opening and mark where the door needs to be cut, cut out the door section and weld in the straight angle pieces. The trick is to maintain the proper window opening gap while welding in the new angle sections and to keep the warpage at a minimum. If you are an experienced welder it is not much of a job...if not, practice on something else before you screw up your truck doors.
Old Mar 9, 2017 | 07:40 PM
BTclassics's Avatar
BTclassics
I'm going through the process right now. Just started building the new window channels. My doors were not straightened, so I have to go with the curved extended window lifts and curved glass. The best instructions I have found are at MidFifty: Instructions - Mid Fifty F-100 Parts
If you go the curved glass route, I may have a brand new set of curved 1 piece windows that won't work with my chopped top.
Old Mar 9, 2017 | 08:38 PM
EBEAR's Avatar
EBEAR
Was hoping to go flat but where are you located in case I go that way
Old Mar 9, 2017 | 08:44 PM
BTclassics's Avatar
BTclassics
It would have been nice if I could have used flat.
I'm located in NY, 3 hours south of Montreal.
77megacab
34
Feb 12, 2021 11:33 AM
8pack
May 17, 2019 09:07 PM
EBEAR
Apr 26, 2017 07:58 PM
1950FordF1
Ford Truck Parts for Sale
May 25, 2016 11:15 PM
Jon Henry
1947 and Older Ford Trucks
Mar 5, 2005 08:48 PM
