8ba oil line pics
Old Feb 16, 2017 | 09:43 PM
3twinridges's Avatar
3twinridges
8ba oil line pics
Anyone got any pics of the oil lines they can share? I have seen lines going outside the manifold and inside. I think I have all the right fittings but need to make new stainless lines and want them to look like original. Having a hard time finding original though.
JB
Old Feb 16, 2017 | 10:42 PM
49f68canadian's Avatar
49f68canadian
Hope you can see them. 1949 Canadian 8ba
canadian 8ba oil lines
Old Feb 16, 2017 | 11:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Mine is roughly the same, ducks behind the exhaust manifold and around the dipstick tube.
Old Feb 18, 2017 | 03:11 PM
F-1's Avatar
F-1
Wow..I like what you guys did..here's mine thinking I needed to keep it away from the exhaust manifold as mush as possible.
I'm going to be a copy cat..thanks
Old Feb 19, 2017 | 10:08 AM
3twinridges
The line size, is it 1/4"?
Old Feb 19, 2017 | 01:27 PM
3twinridges
Also, anyone know the size of the elbow in the block next to oil sender? And if it's reproduced?
Old Feb 19, 2017 | 02:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Look at the way F-1 (above) did his at the block. You're better off making a bend in the tubing, IMO, than using an elbow. What are the chances the elbow will be pointing straight up when fully tightened? Not great. To do like he did, you need a NPT-to-flare adapter. If you really want the elbow, it's a hardware store item.
Yes, the lines are 1/4". Do you have an orifice fitting?
Not exactly correct for your year, but the '51-'53 factory way of plumbing it is to have the sender in a Tee up near the canister, where there is easy access. Once the engine is in the truck, you have to be a contortionist to get at the sender on the BH. Easiest way is by taking out the tunnel cover and using a stubby wrench, flat by flat.
Old Feb 19, 2017 | 02:28 PM
petemcl's Avatar
petemcl
I ran a steel line from the canister down between the block and headers to the port on the side of the block.
Old Feb 19, 2017 | 07:47 PM
3twinridges
Yes I have the restrictor going into the canister and picked up a 1/4 to 1/8 adapter today that should allow me to use either an elbow or straight 1/8 to flare. The tee would be nice but finding it without spending $100 on a whole canister has been tough, and I still would have the same fittings coming out of the block just in the top port. The elbow is going to look a lot cleaner if I can get it to line up.
Working on the tee tee but it's a tough find.
JB
Blue7.3
Australia Chapter
Sep 21, 2014 07:01 PM
RK53F100
Oct 30, 2010 09:39 AM
P1ckup Man
13
Apr 13, 2010 08:29 AM
jaredF100
May 19, 2007 09:51 PM
bronczilla
Offroad & 4x4
May 7, 2003 03:00 PM
