Sponsored by: Real Truck
Replacement turbo for 7.3L
Old Jan 24, 2017 | 12:11 PM
Wenaha's Avatar
Wenaha
After 225,000 miles, my turbo appears to have failed -- not spinning. This is a stock turbo that is unaltered. Yes, I change my oil and filter every 3000 miles.
My question is; what is a reliable after-market replacement part that will bolt up?
Your help is appreciated.
Mike
Old Jan 24, 2017 | 12:20 PM
andym's Avatar
andym
I would take the turbo apart and see what failed before you go shopping for a whole new unit. They're about $600 or $700 for a reman, but you might have other damage or problems that you don't know about, or a simple rebuild might get you back on the road.
Do you let it cool down before you shut it off, or do you kill it as soon as you put it in park?
Old Jan 24, 2017 | 01:43 PM
99f350sd's Avatar
99f350sd
Get it rebuilt or get a kit?
Old Jan 24, 2017 | 02:02 PM
Wenaha's Avatar
Wenaha
Thank you for your responses. I will get it apart and see if I can find what failed.
Then the reman Garrett units are better than an aftermarket replacement?
Old Jan 24, 2017 | 03:31 PM
99f350sd's Avatar
99f350sd
Upgrade Rebuild Kit Powerstroke 7.3L TP38 GTP38 Turbo+Compressor Wheel 66/88 6+6 | eBay
Old Jan 24, 2017 | 08:43 PM
cyncwby's Avatar
cyncwby
The turbo grenaded itself on my '02 F250. I bought a really good reman from Ron's Turbo in Salt lake City, Ut. He installs better bearings and this unit had a Banks impellar which let it spool up quicker for better boost at a lower rpm. It cost about $675 to the door.......... I might add, a real pain the keester to install, for me anyway but it woked great.
Old Jan 25, 2017 | 07:09 AM
Kdr358's Avatar
Kdr358
I replaced my factory turbo with a Garrett 38r, much better over stock!
Old Feb 1, 2017 | 03:37 PM
Wenaha's Avatar
Wenaha
THANKS! The problem may be a bad sensor -- trying to track it down.
Old Feb 1, 2017 | 03:41 PM
Wenaha's Avatar
Wenaha
Problem MAY be a sensor... trying to sort it out.
Thanks,
Wenaha's Avatar
Wenaha
Sorry about the double post.
Old Feb 2, 2017 | 02:34 PM
brian42's Avatar
brian42
Veteran: Navy
The stock turbo is made by Garrett (GTP38)
ford7.3l
Feb 12, 2014 10:04 AM
bigtexan99
Sep 4, 2013 07:59 AM
06stroke
Mar 20, 2008 01:53 PM
D8chumley
Jan 13, 2008 09:20 AM
bphillman
Jan 4, 2007 05:47 PM
