Sponsored by: Real Truck
AC only runs when it wants to
Old Jan 23, 2017 | 05:13 PM
BobKid's Avatar
BobKid
2012 F250 6.2L - AC will be working well with all fan speeds, then airflow just stops and compressor kicks out. Will run (or actually not run) that way for 4-5 minutes, then all of a sudden the compressor kicks in and airflow restarts, and air is nice and cold for another 10 minutes or so when it'll cycle off on its own again.
I've tried all different combinations of AC/MaxAC/fan speeds/and temp settings with no change in behavior. Only occurs in warm weather when AC is on; when just using heat the blower never changes on it's own and everything is great.
Any ideas?
BTW - I've looked through all the HVAC FAQs and probably 200 different threads that come up under different search terms, but haven't seen this particular problem. If it was just lack of cooling but airflow didn't change, then it'd be easy. Or if it was only blower issues in certain speed settings, that's got lots of fixes too. But nothing where cooling and fan quit and restart on their own together that I've found.
Old Mar 10, 2017 | 08:10 AM
BobKid's Avatar
BobKid
No ideas from the group?
Old Mar 10, 2017 | 08:20 AM
alloro's Avatar
alloro
My first thought would be a contact in the selector switch that only engages in the A/C positions is faulty.
Old Mar 10, 2017 | 08:32 AM
Mike1's Avatar
Mike1
Does the whole system die, or is the air just diverted to another vent?
Does the blower shut off when the AC compressor kicks out?
Is the clutch on the compressor actually disengaging?
Old Mar 10, 2017 | 08:49 AM
BobKid's Avatar
BobKid
Blower stops when AC compressor first kicks out. Compressor clutch does engage normally at first, but kicks out after 5-10 minutes and short cycles thereafter. You can sit and watch it engage, disengage, engage on a 30 second cycle until it finally kicks back in and runs after 5 minutes or so.
I have noticed that lately with the weather fairly mild that it will run longer if I keep it in the Max AC setting, but even that will eventually cut out. Pretty much anything over ~80* ambient and I only get a couple of minutes at a time with it running.
One other thing I noticed when I tried to do the clutch air gap check is that I cannot get the compressor clutch to engage when the truck isn't running. Makes it about impossible to get that face bolt loose to check the spacers.
Old Mar 10, 2017 | 09:41 AM
agpopp's Avatar
agpopp
Sounds like it could be a bad/stuck high pressure switch. Can you dig up the test procedure and a multimeter?
Old Mar 10, 2017 | 10:09 AM
projectSHO89's Avatar
projectSHO89
The compressor clutch is controlled by the PCM's software. It won't activate the clutch until all the operating parameters are met.
The gap is set/checked with the clutch de-energized using a set of feeler gauges.
Old Mar 10, 2017 | 10:12 AM
Mike1's Avatar
Mike1
Could be pressure sensor, but I would think either low on freon or the gap in the clutch.
Turn your ignition to the on position, while in AC mode, this should make the clutch engage so you can loosen the bolt. Once the bolt is loose, then turn the ignition off.
Old Mar 10, 2017 | 10:49 AM
BobKid's Avatar
BobKid
I know my gap is slightly too large, so wanted to remove a spacer or two to get it back in spec. To lock the clutch for removal of the center bolt, I need to engage it. All the videos and write-ups just talk about taking the ignition to the RUN position with AC selected and it should engage. Mine doesn't unless I start the truck.
Old Mar 10, 2017 | 10:51 AM
BobKid's Avatar
BobKid
Thanks, I've got a decent set of gauges coming in tomorrow and can finally check my pressures then.
Tried that procedure and my clutch won't engage unless the truck is actually running.
Old Mar 10, 2017 | 11:16 AM
xcrsp440's Avatar
xcrsp440
I think the fan is the key here. Years ago I had a car that developed these symptoms. Fan only worked on speeds 3-4. Settings 1-2 gave no fan output. HVAC compressor would only engage when fan set to 1-2 (no blower). Turn fan to setting 3 or 4, blower kicked in but compressor shut off.
This was caused by a short in the fan's resistor block triggering the HVAC to shut down like the air was turned off.
Somehow the fan turning off is signaling the a/c to shut off.
Old Mar 10, 2017 | 11:28 AM
BobKid's Avatar
BobKid
Thank. Hoping that's not it since the fan selector seems to make no difference in behavior, but I'm running out of ideas.
Anyone have a circuit diagram handy? Would like to see just how the different switches interact to troubleshoot in a more coherent manner than I am now.
Old Mar 10, 2017 | 11:47 AM
alloro's Avatar
alloro
I don't think that works because the clutch draws too much current and would drain the battery. As a safety feature the engine has to be running in order for the clutch to be able to engage.
Old Mar 10, 2017 | 11:49 AM
alloro's Avatar
alloro
Got a strap wrench?
Old Mar 10, 2017 | 11:58 AM
BobKid's Avatar
BobKid
Originally Posted by alloro
Got a strap wrench?
Yeah, just a nasty area to get a bite on it.
