What Gear Oil and Additive for Sterling Limited Slip Rear
Old Jan 15, 2017 | 08:52 PM
VaFordman26's Avatar
VaFordman26
Need to change the gear oil in the rear end of my 95 f250 powerstroke with the Sterling 10.25. Axle code is C5 limited slip with 4.10s.
Should I use 80-90w or like a 90-140w and what additives or friction modifiers do I need to get? And then what's the capacity and ratio I need to add?
Thanks
Old Jan 15, 2017 | 09:25 PM
mrollings53's Avatar
mrollings53
From the 1996 owner manual.
Old Jan 16, 2017 | 04:45 PM
GeoTerra's Avatar
GeoTerra
I did this recently and used a synthetic that met Fords Specifications.
Old Jun 21, 2017 | 10:22 AM
VaFordman26
Originally Posted by mrollings53
Attachment 170858
Thanks for the info. Do you know what the capacity is? 95 F250 7.3 ECLB 4x4 auto 4.10LS
Old Jun 21, 2017 | 10:58 PM
abranz's Avatar
abranz
I just put 3.75qt in mine
Old Jun 22, 2017 | 11:05 AM
VaFordman26
Cool thanks man. Amazon has a good price so I'll just grab 4 and 8 oz of the friction modifier. Can't beat prime with free 2 day shipping
Old Jun 22, 2017 | 06:08 PM
'89F2urd's Avatar
'89F2urd
With pretty much any synthetic gear oil, you're supposed to run the fluid by itself and add friction modifier only if you get chatter.
Old Jun 23, 2017 | 01:23 PM
VaFordman26
Even with a limited slip axle? I've always thought LS always gets the additive. This is my first truck that's had it out of about 6
Old Jun 23, 2017 | 02:24 PM
'89F2urd's Avatar
'89F2urd
Correct. The additive is specifically for LS differentials, however, all mainstream synthetic brands have modifiers already...so you don't want to go crazy with friction modifiers if they aren't needed. Many bottles, in fact, instruct you not to add modifier unless you get chatter.
Old Jul 2, 2017 | 07:48 AM
VaFordman26
So if I get 4 qts of the motorcraft stuff in the link above I don't need to use the modifier?
renoduckman
May 6, 2012 03:31 PM
Brooksd1991
Oct 13, 2009 06:08 PM
zomowiec
Sep 23, 2006 06:26 PM
351kid
Sep 10, 2004 10:18 PM
waltmoe
Feb 15, 2002 02:33 PM
