Servicing front and rear end
Only if you have a limited slip diff will you need the limited slip additive. You can get the gear oil with the additive already in it or you can get it seperately and add it to the axle before you put the gear oil in.
Ask at the store for limited slip diff additive or look on the gear oil container for "contains limited slip sdditive" or contains "friction modifier" and you should be OK.
