Howfy folks I'm trying to track down a 172 code HEGO lean- o2 sensor reading lean.
My truck is a 1995 f150 with the 5.8 and speed density.
I havent replaced the sensor yet because I have read many other posts that say it's other things and I've checked them. I need help!
I've checked for vacuum leaks with carb cleaner, replaced all hard plastic lines with rubber, replaced my throttle body gasket, checked pcv valve and made sure it was sealed well, and checked egr. I am at a loss and don't know where to go from here.
Am i able to check resistance in the o2 sensor wiring or something? Could it be shorted out? I have an oil pan gasket leak and my wiring and sensor is covered in filth, could that be causing it?
I havent checked fuel pressure but I put a new pump in a few months ago and figured it would be good. Also I get a faint gas smell from the fuel pressure regulator vacuum line.
Thank you Tye
Reason: More info
Clean up the connector real good with non contact electrical cleaner. I had the same issue with the leaky gasket and dirty connector. Replaced the sensor with no luck. Cleaned up the connector real well and the CEL finally stayed off.
clean the o2 sensor plug? also what gasket are you referring to?
i replace the o2 sensor about 60,000 miles ago so it could be bad?
I had a new Ford unit go bad after just a few months, and went through extensive diagnostics because I figured the new unit being bad was the least likely scenario. Found a few problems, but in the end the new Ford sensor was bad.
Oil can and will penetrate and corrode seals and connectors.
Get your hands on a Fuel Pressure gauge and Vacuum gauge and get some real numbers.
I will do all you guys mentioned! Thank you much for all the help! I'll get a couple testers and throw the readings back up here!
How big big of a pain is it to do the oil pan gasket? Also would it be good to do the rear main seal while I'm in there?
Oil pan gasket is a hassle since the cross member is in the way and you can't take the oil pan out. You basically have to fish the new gasket around the oil pump and pickup.
I fought with a check engine light and excessive spark knock for months. I replaced the o2 sensor twice, mass airflow sensor, temp sensor check for vacuum leaks, inspected wiring, cleaned and inspected connector till I finally decided I would replace the ecu. I checked for discount codes online for Advance Auto and found one for 30% off for orders bought online over 50.00. I replaced it and havent had another CEL since. Also the truck runs much better and the gas mileage is much better.
