Just love throwing $$ at these old trucks
Old Nov 16, 2016 | 09:41 PM
ceccacci316's Avatar
ceccacci316
I picked up a 1997 Ford F-350 with 51K miles on it in September.
I expected to put a few dollars into it, based on what the PO told me had already been done. Well I just keep giving.
1) Took it into the shop to have the trans and diffs serviced, oil change, and the rotting leaking power steering lines replaced; and it needed front brakes; wait the PO said they were good? out the door $827
2) Needed a new windshield $180
3) PO said it was a brand new battery, not. $157
4) Wiper blades, K&N air filter, head light switch, breather filter, $92
5) Needed a Rt door mirror, had to search long and hard for that and found one for $50 on Ebay,
6) Then ... had issues getting into 4WD low ... $430 to rebuild the transfer case.
7) Started to leak coolant - $453 to have the radiator replaced
8) Needed some floor mats and door panel clips $38
9) Was fine for a few days, another coolant leak .. on the way to the shop the bearing on the AC delete pulley froze ... to have that replace and a new water pump $433
10) Was all good for two days, started leaking like a sieve ... towed back to the shop ... going to need a thermostat - $120
11) Oh and I ordered some aftermarket exterior cab lights for $23, just waiting to get the truck back.
Just needed a safe space to vent :-)
Just wondering when I will think enough is enough ..... as I think to myself the truck is really solid for a 20 year old vehicle .. except for the rot in the lower radiator support ... which will most likely need to be addressed .. maybe in the spring?
I am just addicted to keeping these old vehicles alive and kicking :-)
Old Nov 16, 2016 | 11:42 PM
GoinBoarding's Avatar
GoinBoarding
Ouch. These things are hard to call economical when you're paying for labor. I'd be a little disappointed with the shop though. Seems like standard operating procedure to replace the thermostat and coolant hoses with the water pump.
It also sounds like a sitting truck is worse off than a driven and maintained truck.
Old Nov 17, 2016 | 12:25 AM
westcoasting's Avatar
westcoasting
Well an easy way to think about it... that money would only be about 3 or 4 truck payments on a new one which would be depreciating every day you drive it. At the end of 8 years of payments you would then have a truck worth 10 000 maybe!
Old Nov 17, 2016 | 12:29 AM
GoinBoarding
^^ That's true. I justify every repair or modification to my truck in the same way. "well, this would only be 2 weeks of payment on a new one..." Or I think, if this keeps me from buying a newer truck for another couple years, it pays for itself.
I guess I just cringe at any repair bill, fair priced or not. I sometimes forget not everyone was brought up around wrenches or even have the time to do repairs themselves.
Old Nov 17, 2016 | 02:17 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Fluid changes & front brakes depending on if just rotors less than $200. Around $100 for a radiator delivered to your door. Last thermostat I replaced was $10. As mentioned, if you are going to be paying labor for everything then it will quickly deplete your bank account.
Old Nov 17, 2016 | 07:38 AM
Jblack's Avatar
Jblack
I've had to put about 2K into mine already. About half of it was planned. BUT I'm not making a $350-500 payment every month. Or losing money when it's time to sell a newer truck because of the huge up front cost.
There is no other way to look at vehicles other than they are a net loss. It's the price we pay to haul our butts from one place to another.
Old Nov 17, 2016 | 08:14 AM
DSparksF250's Avatar
DSparksF250
Bought a $500 beater to learn how to do all that stuff.
Right now I'm solving the clutch, into it about $100, but if it goes right, that's $100 I had to spend but got educated on how the clutch works, and how to fix it.
A mechanic would probably charge me $300 minimum for this, and if it failed again, I'd have to go back.
Old Nov 17, 2016 | 12:13 PM
BruteFord's Avatar
BruteFord
Old Nov 17, 2016 | 03:04 PM
seschenburg's Avatar
seschenburg
Bought my 94 about a year ago. About 7 months later the harmonic balancer came loose. The resulting imbalance fractured the crankshaft. $2000 for a long block replacement later, + miscellaneous parts, and I've doubled my "investment". I feel your pain.
Old Nov 17, 2016 | 03:09 PM
Unaffiliated's Avatar
Unaffiliated
To be honest I don't care about the money I spend, because when I hop in my truck and start it up I'll always have a smile on my face.
Old Nov 17, 2016 | 03:15 PM
Glenn54's Avatar
Glenn54
I know what you mean. Bought my truck a couple of months ago and it has 87K miles. AC fixed, only $100. On the way to get new tires, oil pressure sending unit broke. Wrecker bill and repair $200. Tires about $600. In the process of replacing door latch cables and handles. Purchased inside and outside window seals for doors, about $150. Ordered new power window motor today, $88. Need to have rear window replaced. Noticed oil on garage floor yesterday, pretty sure it's brake fluid. Replace radio $200. Speakers are also being replaced, $200.
Old Nov 17, 2016 | 04:12 PM
Fastback460's Avatar
Fastback460
A lot of us know how you feel man. But there is just something about these trucks that I love, it's the only thing I drive that just feels right.
I've had my 97 for 6 years, and I have over $14,000 invested into it. I've had quite a few people tell me I'm out of mind for putting that much money into a 20 year old gas guzzler, but at the end of the day I have a truck that is in great shape that I love to drive.
I did a lot of the repairs myself, but the bigger jobs I had done by a shop (rebuilding the heads, re-built transmission and bodywork).
Old Nov 17, 2016 | 04:22 PM
BruteFord's Avatar
BruteFord
I picked up a 1986 Ford F-350 Crew-Cab dually for $300 with I don't care how many miles on it a while ago.
I expected to put only a few dollars into it, based on what the PO told me had happened. That the motor made all these horrible noises, smoked a lot, quit, and hasn't moved since. Well I just keep winning.
1) I already had a good idea what was wrong from looking at it there BEFORE I bought it, $0.
2) Hauled it home on the family trailer behind my other F350, $20 in fuel.
3) The positive battery cable had rubbed through on the frame, put a chunk of hose and some electrical tape around it, $0.
4) Tossed in an old battery I had on a charger in the garage, $0.
5) Needed some fuel, toss 5 gallons in each tank and a couple ounces in the carb, $30.
6) Then ... Fired it right up and drove on laughing. $Priceless.
Just needed a safe space to brag :-)
Just wondering when I will think I'll have enough of these awesome cheap to own trucks ..... as I think to myself the truck is really solid for a 30 year old vehicle .. I'll fix it up a bit more and probably sell it.. maybe in the spring?
I am just addicted to having trucks I love so cheap.
Old Nov 17, 2016 | 04:37 PM
ceccacci316
Yep, I had them inspect the hoses and they all looked good but one they replaced. The others must have been replaced sometime in the past.
Old Nov 17, 2016 | 04:39 PM
ceccacci316
I agree, at this point i have a 20 year old truck with a lot of updates that is paid off.
