Need help identifying this skid plate/cross member 1995 F150 2WD
Old Nov 16, 2016 | 04:34 PM
fstbck1970's Avatar
fstbck1970
Need help identifying what this plate is that runs across the frame, almost like a cross member or skid plate, right behind the accordion section at the front. Somehow about a year or so ago it got bent (not even sure how, just looked under there one day and it was bent, never bottomed out while offroad or been in a fender bender that would have caused it), and I was looking to either replace it or see if I can just hammer it back out. Anybody else have this happen to them or know what it is?
Old Nov 16, 2016 | 04:42 PM
seschenburg's Avatar
seschenburg
If you had a sway bar it would attach to the back side. Two holes at each end would hold a strap that goes over the sway bar bushing.
Hammer it straight again and you'll be fine.
Hitting water can also bend things. Maybe driving through a big puddle?
Old Nov 16, 2016 | 04:48 PM
fstbck1970's Avatar
fstbck1970
Didn't think of that, good to know. Is there a big difference between the stock sway bar and not having one at all? Is it worth picking one up?
Hard to remember because it was a couple years ago now, but might have been, only real deep water I ever went through was in Houston and I know it happened before I moved there.
Old Nov 16, 2016 | 04:59 PM
seschenburg
Other forum comments I've seen say that they don't make a heckuva lot of difference unless you're racing a heavy hauler on a circular track. I have one, but have no comparison to relate it to. Sorry.
Old Nov 16, 2016 | 05:09 PM
Unaffiliated's Avatar
Unaffiliated
PO of my 1996 used it to winch the truck out of the snow. It was bent and pretty much served no purpose apart from being an ugly turd. I made a custom skid plate out of aluminum, wouldn't even consider switching back to a OEM one even if it's in good condition.
kramttocs
Dec 31, 2018 06:25 AM
Rotten Banana F150
Aug 11, 2013 02:14 PM
TheWhiteBeast
Dec 29, 2011 08:55 PM
BCHauler
Oct 27, 2008 12:58 PM
Tylus
2004 - 2008 F150
17
Oct 11, 2007 06:13 PM
