1989 bed bolts
Old Nov 16, 2016 | 02:05 PM
wharthog's Avatar
wharthog
1989 bed bolts
To those of you who have swapped or just pulled your beds, (wait this is for those rust belt truck guys). What bolts did you use to replace the OEM bolts? Mine are not worth reusing, heck, two of them would have to have added steel cut from the top of them. Had to weld retaining devices to the top due to them spinning while trying to remove them.
Old Nov 16, 2016 | 06:22 PM
tjc transport's Avatar
tjc transport
i ain't rite
you can still buy them from ford, but it is going to cost you around $130
or you can get some carrage bolts and call it good for around $10
Old Nov 16, 2016 | 06:28 PM
wharthog's Avatar
wharthog
Thanks Tom. I going to see if I can get button head allen bolts, just thought of those after looking over the ones I pulled out.
Old Nov 16, 2016 | 06:36 PM
tjc transport
i ain't rite
if i remember correctly, 5/8X6 inch is the size you want.
the originals were metric.
Old Nov 16, 2016 | 08:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Grade 8 bolts, flat washers and Nylock nuts. The zinc coating on the grade 8 resist the rust the best. And if you are worried about the head of the bolt getting caught when sliding things in the bed, DONT. They sit below the ribs of the bed.
Also they are 1/2 diameter bolts you want.
4 are one length 2 are another
Old Nov 16, 2016 | 09:46 PM
TeeRob's Avatar
TeeRob
haha I just went up to Lowes (home improvement store) and picked up some Grade 8 bolts with washers, dont remember the size though.
Old Nov 17, 2016 | 12:19 AM
westcoasting's Avatar
westcoasting
Stainless bolts would seem like a good investment.
Old Nov 17, 2016 | 04:47 AM
Diesel_Brad
Stainless is brittle. i would never trust them in that application
Old Nov 17, 2016 | 10:30 AM
westcoasting
Yes excellent point!
Old Nov 17, 2016 | 11:25 AM
BeholdenZippy's Avatar
BeholdenZippy
Putting anti-seize on the bolts would also be a good idea.
Old Nov 17, 2016 | 08:29 PM
wharthog's Avatar
wharthog
Wow, just found out after working on my superduty bed that the bolts I got from RAP will work out great, so I ordered another set for my "89" f150, should work out fine.
Old Nov 18, 2016 | 06:57 AM
Diesel_Brad
You must not have a rust issue where you live
Old Nov 18, 2016 | 07:43 AM
wharthog's Avatar
wharthog
Why do you say that? I do have rust issues here, we are a salt state, I'm in Michigan. I have had the bolts I'm talking about have been in my super duty for like six months. I do keep a vinyl cover on the bed most of the time but they do get exposed to the weather. I don't know what type of coating is on the bolts but they are keeping their finish. Time will tell. I do like the fact that the bolts you spoke of have a head that is below the crown of the ribs in the bed. The grade eight bolts you spoke of, are they button head allen or hex head? Because if the ones in the bed now start to rust, the ones you spoke of will go in.
I HATE RUST!
Thanks Diesel_Brad. Please let me know on the bolts.
Dennis
Old Nov 18, 2016 | 07:46 AM
wharthog's Avatar
wharthog
I almost always use anti-seize, when I don't I use thread locker of some sort.
Old Nov 19, 2016 | 08:43 AM
Diesel_Brad
I HATE RUST!
Dennis
The problem with the SuperDuty bed bolts is 2 fold
1. They are a self taping bolt that strips of any antiseeze you may put on.
2. the metal clips rot away and then when you go to remove the bolts, the clips break and just spin.
You would be MUCH better off with a regular Nut and Bolt
