Aftermarket Products
Sponsored by: Worksport
4-speed manual (4th overdrive) for a 3.9
Old Nov 8, 2016 | 02:10 PM
stormy750's Avatar
stormy750
Hello all:
I'm interested in finding out if there ever was a 4-speed manual (4th being overdrive) that was produced for the 3.9l/240 CID straight six?
Old Nov 8, 2016 | 10:55 PM
85e150's Avatar
85e150
Not on the 240. But Ford did install the SROD and it's variants behind the 300. My van had the iron cased side shifted unit. 2nd to 3rd is a big gap.
IMO, for the effort involved, spend a little more and get a T5.
What vehicle are you going to use it in?
Old Nov 11, 2016 | 06:41 PM
stormy750's Avatar
stormy750
4 speed standard ( 3 speed with a 4th OD) for a 240 six
Thanks for the reply, 85e150six4mtod.
It's for an F100 1/2 ton, 1967. What's a "T5"?
Old Nov 11, 2016 | 07:50 PM
85e150's Avatar
85e150
T5 is the 5er used in Mustangs and tons of other vehicles from Ford and GM. There are several varieties. If you are not working the truck heavily, and depending on your rear axle ratio, it could be an answer.
Links give more T5 info. The thing about it is it will bolt to your bell, although it may require an adapter. That said, your clutch setup remains the same.
TREMEC 5-speed 6-speed Transmission Conversion solutions Ford Mustang, Falcon, Cobra, Hotrod, GM Camaro, Chevelle, Tri-5, Mopar Muscle
Click around on that site for info etc. They are good to work with if you go that way and need something like an adapter.
T5 Swap, T5 Conversion, Mustang T5 Swap, Auto to Manual Transmission - FordMuscle
Although they are talking about a Mustang, not many details change when we are talking about a truck like yours.
Ford Mustang: Mustang Tech: Transmission and Drivetrain: Borg Warner T5 Transmission data
gives a listing of what's in what.
Note certain GM S10/15 models had a trans that will work in a Ford as well. Gotta search that one out if need be.
Frankiegirl
Jan 19, 2015 07:56 AM
DHCowdude
Apr 3, 2011 07:27 PM
Fast John ll
Feb 10, 2005 05:13 PM
OldSchoolRodz
28
Jan 30, 2005 01:15 PM
inliner
13
Jul 16, 2001 06:53 AM
