8-13-2010 build date good of bad
Thanks again, and I am trying to do a search on all my questions, and have learned a lot already, but it not easy to find ALL the answers.
Maintain it..use a fuel additive Ford makes... and you should be good.. I had turbo replaced at 105k... which they have changed design since then..and AC evap at 70k... that's it.
Not sure of any glow plug issue but I don't read every thread here.
Bruce...
Then there is the question what would be more reliable, a well maintained 2011 or a abused 2012? I will need a truck with en the next two weeks so I can't be too picky
You are fortunate that you're an educated potential 2011 owner. Plenty of threads here of unsuspecting buyers having the catastrophic experience shortly after taking ownership and Ford offering no help.
Bruce...
The choices I have is another 6.0, but after looking at the newer trucks the 05-07 just don't look that nice any more, my wife even feels the same way. I can go with a 6.4, lots of them in my budget, but heard some really bad things about them. Or, buy the 2011 and gamble. I thing my odds are better with the well maintained 2011 than a 6.4. So I will go look at it tomorrow.
Because of the issues with the early Job 1 trucks I would never consider a used one.
There have been a few 2012 models with turbo issues, but I don't know what is different with the turbos from 2011-2013.
6.7 DIESEL – RUNS ROUGH – NO CRANK – GLOW PLUG CIRCUIT DIAGNOSTIC TROUBLE CODES (DTCS) – BUILT ON OR BEFORE 3/29/2011
TECHNICAL SERVICE BULLETIN
Reference Number(s): 12-11-11 Date of Issue: November 16 2012
FORD: 2011 F-Super Duty
ISSUE
Some F-Super Duty vehicles equipped with a 6.7L diesel engine and built on or before 3/29/2011 may exhibit a runs rough or no crank concern. DTCs P0671, P0672, P0673, P0674, P0675, P0676, P0677, and/or P0678 may be stored in the Powertrain Control Module (PCM). The glow plug circuit DTCs may also be accompanied by cylinder misfire DTCs, cylinder contribution DTCs or other engine performance DTCs.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Does the vehicle exhibit a runs rough, no crank concern with any of the following DTCs P0671, P0672, P0673, P0674, P0675, P0676, P0677, and/or P0678?
a. No – this article does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
b. Yes – proceed to Step2.
2. Remove and inspect the glow plug associated with glow plug circuit DTC present. Refer to Workshop Manual (WSM), Section 303-07C. Is the glow plug damaged?
a. No – this article does not apply. Refer to the PC/ED manual for normal diagnosis.
b. Yes – replace the engine long block. Refer to WSM, Section 303-01C.
i. For prior approval warranty repairs, complete cost cap tool by selecting short block, both cylinder heads, oil cooler and 16 lifters.
PARTS INFORMATION
Part Number Part Name
BC3Z-6006-F Long block
BC3Z-6079-B Installation Kit
WARRANTY INFORMATION
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB.
IMPORTANT: Warranty/ESP coverage limits are determined by the identified casual part and verified using the OASIS part coverage tool.
Operation Description Time
121111A 2011 F-Super Duty 6.7 L Check DTCs, Inspect 18.0 Hrs.
Glow Plug, Replace Long Block (Can Be Claimed
With Operation B)
121111B Additional time to contact hotline and complete 0.3 Hr.
Online forms. This operation is to be used only for
Dealerships that require prior approval (Can Be
Claimed With Operation A)
DEALER CODING
Basic Part No. Condition Code
6505 01
My 2011 that blew up was built 07/10. I hope yours is a good one.
