Heat soak? Bad coil? Help!
Old Sep 24, 2016 | 03:47 PM
Tonyg1723's Avatar
Tonyg1723
I am having a problem with my 83 F350. When the truck gets to about 180 degrees, it completely dies. No starting to sputter, nothing. It just dies. Will not start again until cools down. I have a new Holley 750 on it; thought maybe it was heat soaking, so I put a heat shield on, but it still does it. I have also replaced rear gas tank, new coil, new ignition control module, 160 degree thermostat, but it hasn't helped.
I am at a loss for what is going on. I thought if it wasn't heat soaking that replacing the ICM would solve problem
Any advice or ideas are appreciated, I don't know what to do at this point.
Old Sep 24, 2016 | 06:48 PM
FuzzFace2's Avatar
FuzzFace2
You are going to need to do more testing if it is lack of spark or fuel before we can guide you down a path.
Now if you think heat is the cause you could take ice in a bag and pack it around the coil to see if that changes anything.
If not move the bag of ice to the IGN box to see if that does anything.
Could also pack the carb but I cant see it as a cause as it would not just "shut down at 180*". Most of the time heat soaked carbs show up after you have the truck running for a bit and you shut the motor off like running into a store and when you come out it will not start.
Dave ----
edit: I take it you have a v8 being you have a 750 carb but what size?
Old Sep 24, 2016 | 06:52 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Engine displacement would help.
If you've replaced the DSII module you should check the distributor pickup.
Do you have a multimeter?
Old Sep 24, 2016 | 07:40 PM
Tonyg1723's Avatar
Tonyg1723
Dave ----
Hah, forgot to mention that with all the frustration. It's 460.
Old Sep 24, 2016 | 07:45 PM
Tonyg1723's Avatar
Tonyg1723
460. I don't have a multimeter, but I did buy a new distributor for it. Hasn't been put on yet though.
Old Sep 24, 2016 | 08:13 PM
kr98664's Avatar
kr98664
How repeatable is the problem? Can you duplicate it in the comfort of your driveway? When the engine dies, test for a spark right away if possible. That should point you down the correct path.
How old is the coil? If more than a few years old, I'd gamble on a new coil and see what happens. I guess it all depends on how much troubleshooting you want to do. But if the issue is a loss of spark, and you've already tried the ignition module, a new coil is a reasonable shot.
Old Sep 24, 2016 | 10:11 PM
Brnfree's Avatar
Brnfree
Does it act like it's running out of gas before it dies? If so, vapor lock? Fuel pump? Fuel filter?
Otherwise, if it quits like you shut off the key it's probably ignition and based on what you've already replaced I'd guess the magnetic pick up inside the the distributor.
Based on recent experience with a bad coil it didn't quit but it did miss, back fire and cut out under a load.
Old Sep 24, 2016 | 10:48 PM
Tonyg1723's Avatar
Tonyg1723
Problem is extremely easy to duplicate. Does it every time gets up to about 180 degrees, and won't start again until it cools and hood popped. The coil is brand new.
Old Sep 25, 2016 | 06:05 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So, you may as well replace the distributor, since you have it and you dont have a meter to ohm out the ignition pickup.
(450--950 across orange & purple at the plug)
Does your truck have a tach?
When the engine shuts off does the tach drop to zero even before the engine stops spinning?
Old Sep 25, 2016 | 06:57 AM
kr98664's Avatar
kr98664
Uff da! Missed the mention of the new coil in your original post. Time for everybody to mark their calendars as I was less correct than usual.
When did the problem start? Any other recent work done? While waiting for everything to cool down, have you confirmed the loss of spark?
Old Sep 25, 2016 | 07:05 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How do you know it's 180 degrees?
Are you using an IR thermometer or an aftermarket temperature gauge?
***get rid of the stupid 160 degree thermostat***
You are not allowing the engine to reach proper clearances and you are not effectively removing condensation from your oil.
Old Sep 25, 2016 | 12:25 PM
Tonyg1723's Avatar
Tonyg1723
The kids I bought truck from put on an aftermarket temp gauge. What thermo would you suggest, 190?
Old Sep 25, 2016 | 12:33 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
What type of climate do you live in ?
Old Sep 25, 2016 | 12:53 PM
Tonyg1723's Avatar
Tonyg1723
So, you may as well replace the distributor, since you dont have a meter to ohm out the ignition pickup.
No tach. Plan on replacing distributor sometime this week.
Old Sep 25, 2016 | 02:16 PM
Tonyg1723's Avatar
Tonyg1723
Problems started about a month or so ago. I have the new Holley 750 on, new rear tank, new 3 core radiator, new ignition control module, new coil, tranny rebuilt.
