Frame Spacing Dimensions
Old Sep 6, 2016 | 10:35 AM
Pokee's Avatar
Pokee
The transmission mount was cut out on my 1950 ford and the cab mounts were loose. Can anyone tell me what the frame spacing should be at the transmission mount location? I need to build a mount for my aod transmission. Thank You
Old Sep 6, 2016 | 06:07 PM
DougofMontana's Avatar
DougofMontana
I can go out and measure my '49 frame, but I'm not real sure of what dimension you are looking for exactly.
Old Sep 6, 2016 | 06:23 PM
oneye's Avatar
oneye
This might help?
Old Sep 6, 2016 | 06:29 PM
Pokee's Avatar
Pokee
Thanks for responding. What I want is distance across the frame rails from the outside edges right behind the top transmission mount rivet. Or between the frame top flanges. Thank you.
Old Sep 6, 2016 | 07:25 PM
DougofMontana
Here's a pic of my frame, the hole in the frame is where the trans mount used to be. Does this help? I'm reading 29 3/8" inside flange to inside flange:
Old Sep 6, 2016 | 08:33 PM
Pokee's Avatar
Pokee
Ok, thanks. Mine measures 29 5/8" at that point. According to my cab mount holes I need to pull to squeeze the frame in 1/4" so they will be 45 1/2" spacing to match the cab. Thanks again.
Old Sep 9, 2016 | 12:47 PM
petemcl's Avatar
petemcl
OK. Here is the trans crossmember that I made to support my 4R70W.
I bolted it to the bottom of the frame.
1low50
24
Feb 13, 2021 07:53 PM
pilot31
WTB - Parts & other
Sep 17, 2016 12:26 PM
ranchrods
Apr 4, 2016 12:35 AM
740buckeye
Mar 28, 2014 05:14 AM
4byford
Jan 12, 2002 01:50 AM
