F450 Supercab?
Old Aug 25, 2016 | 10:37 AM
Tomc750's Avatar
Tomc750
F450 Supercab?
just discovered that Supercab is not available in a 450 pickup? Does not make sense to me. Why not? What about a chassis cab?
Old Aug 25, 2016 | 10:50 AM
fordmantpw's Avatar
fordmantpw
SuperCab is available on chassis cab F450.
Old Aug 25, 2016 | 11:01 AM
troverman's Avatar
troverman
The 450 "pickup truck" historically has only been available as a crew-cab, long-bed, dual-wheel, 4x4, diesel vehicle. Just the way it is.
Old Aug 25, 2016 | 09:30 PM
marcs724's Avatar
marcs724
Don't forget, if you order a cab and chassis, they're derated considerably on HP and torque, have considerably stiffer suspension (as in, it really doesn't move), and I would assume it will be geared a lot lower than a pickup model, as is the case on a 350.
Old Aug 25, 2016 | 10:23 PM
BII Plow Truck's Avatar
BII Plow Truck
Also don't forget the frame is NOT fully boxed behind the cab on a chassis cab......flexy flexy.
Old Aug 26, 2016 | 04:14 AM
troverman's Avatar
troverman
You can actually get a 4.10 axle on a diesel 450 chassis cab, which is taller gearing than the pickup.
Old Aug 26, 2016 | 11:56 AM
Tomc750's Avatar
Tomc750
All very interesting. So if a guy should want a good riding capable truck with wide track and a tow body he is basically screwed?
Old Aug 26, 2016 | 12:08 PM
System's Avatar
System
Prolocutor
You would just need to buy the pickup version and remove the bed. No getting away from crew cab though...
Old Aug 26, 2016 | 04:19 PM
marcs724's Avatar
marcs724
That's exactly what I'm doing. Just ordered a new 350 supercab DRW pickup. I will remove the bed and install my own, and then just put the pickup bed back on down the road when I trade it in. I made the mistake of ordering a cab/chassis once.....worst riding truck ever made lol. But I understand it was made to haul a lot more weight than I haul. I just haul a lot of 'stuff' and not necessarily a lot of weight.
Old Aug 26, 2016 | 09:21 PM
Tomc750's Avatar
Tomc750
That does not work for body builders who need a C channel frame. That is the reason chassis cabs are built that way.
jhl3
6.7L Power Stroke Diesel
Jul 1, 2016 01:43 PM
ArtsBest
2015 - 2020 F150
17
Sep 5, 2014 06:49 PM
ccstp
Sep 7, 2012 05:35 PM
dzc391
Feb 4, 2005 09:14 AM
Don
Jul 2, 1999 06:45 PM
