Another question regarding adding power brake booster
Old Jul 31, 2016 | 02:14 PM
herdfan75's Avatar
herdfan75
Hi folks, just recently purchased a 69 F100 long bed in very solid, original condition. It's a 2WD with power steering but no power brakes. First I need to go through the brakes and make sure they are all good and check the brake lines, shoes, cylinders and hoses (standard checks when you buy an old vehicle). The truck stops fine for manual brakes, but wow does it wear you out! I've been reading the threads here on adding a power brake booster, particularly this thread: https://www.ford-trucks.com/forums/1...nterested.html
I have a couple of questions...would it be better to just purchase a booster for a 1969 F100 and new master cylinder? Would the pedal rod be the same? I've also seen threads about adding a booster from a 1975 F350 with a master cylinder from a early 90's Explorer. What are the advantages of this? Also, I found an A1 Cardone reman booster and MC (part numbert 50-3112) here: https://www.summitracing.com/parts/a...FQ6oaQod9oYGJA Wouldn't this be easier? Also, would I need to purchase an adjustable pedal rod?
Finally, which firewall bracket would be required (the Cardone setup comes with a bracket).
Thanks all! I would drive the truck more if it had power brakes (if I can afford the gas!)
Here's a pic:
Old Jul 31, 2016 | 02:16 PM
351Cleveland C4's Avatar
351Cleveland C4
Explorer MC advantages include a larger bore, and a plastic/aluminum construction that is completely sealed and will not rust.
Old Jul 31, 2016 | 07:39 PM
herdfan75's Avatar
herdfan75
That makes sense. What about the booster and the rod?
Old Jul 31, 2016 | 07:56 PM
351Cleveland C4
There are 2 or 3 recent threads discussing everything you have asked about....
BigB9000
45
Jan 19, 2022 04:00 PM
idealtrucks
Oct 19, 2016 05:50 PM
rc1099
Sep 3, 2009 12:11 AM
Dan76'F100
May 23, 2003 04:41 PM
lsrjf
Oct 30, 2002 02:42 PM
