30's Pick-up on a Ranger frame
Old Aug 17, 2003 | 11:55 AM
H22Andretti's Avatar
H22Andretti
Hi, this is my first post. I am helping a "not-so computer savy" friend with his 32' (I think). He needs a frame for it, he has heard that you can use a 80's Ranger frame for it, and just needs minor alterations. Is this true? If not, is there any other options for a frame.
Thanks, I am sure I will have more questions soon.
Old Aug 17, 2003 | 08:36 PM
hermn8r's Avatar
hermn8r
I have seen a 36 glass truck on the ranger frame. I purchased the info for $35.00 from thoroughbred coach works who sells the
glass 36 pickup.
Old Aug 17, 2003 | 09:28 PM
41Clay's Avatar
41Clay
First of all, welcome to FTE!
I've seen a fiberglass '33/'34 on one in my home town. He has to stretch the frame to get the pickup to fit on it correctly. It shouldn't be that big of a deal, the brackets are pretty simple and can be easily reproduced on another frame. Hope this helps some, if at all.
Clayton
Old Aug 19, 2003 | 08:45 AM
hermn8r's Avatar
hermn8r
The late 80's rangers wheel base came in 3 lengths to match the
trucks for the short,long and regular wheel base. In the manual
you have to cut 10 inches off of the back end of the frame and
seven off of the front the main thing is to get the right wheel
base to match your truck. I have also seen a Mazda pickup frame used. The 36 is 112.5 and I believe the ranger frame to use was the 112 wheel base. I am just going by memory as I have not looked at the manual in a while. I went with a stock frame as I found it was easier because all the aftermarket stuff is geared to it for dimensions and fit. I have a mustang II front and a triangulated 4 bar in the rear. Let me know if you need any more
help I could dig out the manual. I do not know the dimensions
for your truck but I would help you if I can.
Old Aug 19, 2003 | 12:00 PM
H22Andretti
That will surely be a help. He is on vacation right now, but I will get him to measure soon as he is back.
Thanks.
hotrodchic79
32
Mar 2, 2015 01:31 AM
Flathead Red
1947 and Older Ford Trucks
Apr 16, 2012 11:14 AM
Prozon
1983 - 2012 Ranger & B-Series
Dec 6, 2009 02:41 AM
Wooky71
May 18, 2006 08:11 AM
55Bubba
Dec 22, 2003 02:43 PM
