stock suspension and 33's
Old May 6, 2016 | 07:36 PM
mjr46's Avatar
mjr46
So I went to swap my current tires which are 31's over to my freshly painted 87 15x8 f150 rims and dang if I can't win for losing!! the truck sat for nearly 8 years and the tires roll like eggs on the balancer.......so looks like I'm getting new tires now!!! I'd like 33 x 12.50 x 15's.....question is will 33's fit under my truck with no suspension lift? the 31's had plenty of room iirc.......anyone have any insight.....gonna order tires asap if I can figure that out.
Old May 6, 2016 | 09:49 PM
hasteranger's Avatar
hasteranger
I dunno if my truck was stock, but I had a half ton 78 that came to me with 33's but they were the wide ones, 13" or so Iirc, and they rubbed the radius arms and the fender at full lock, and they were a little hard to turn. Tended to make the belt squeal to turn at a stop. Narrower ones would probably fit better.
Old May 6, 2016 | 09:57 PM
fuzzybob's Avatar
fuzzybob
Here's my 77 with 33's. No probs with full lock or any rubbing.
Old May 6, 2016 | 10:06 PM
mjr46's Avatar
mjr46
thanks fuzzybob!! just what I wanted to see...nice truck!!! I assume you don't have a lift? those a re 33x12.50"s?
Old May 6, 2016 | 10:12 PM
fuzzybob's Avatar
fuzzybob
Yes, 33X12.50. I just added a set of leveling springs in the front but I add no probs before I added them. Good luck with your build. Post pics!!
Old May 6, 2016 | 10:37 PM
mjr46's Avatar
mjr46
I have a thread going, just need to update the progress with more pics, thanks again!!!
Old May 6, 2016 | 10:39 PM
orangeford's Avatar
orangeford
I ran 33x12.50 x15 on 15x10 wheels with no lift on my 79 f150 before I lifted it.
You can make them rub if you are in rough terrain but normal road conditions were fine.
Old May 7, 2016 | 12:18 AM
mjr46's Avatar
mjr46
how wide are your rims? mine are 15x8
Old May 7, 2016 | 10:27 AM
crazy96863's Avatar
crazy96863
33x12.5R15 on my 75. Rims are 15x8. Couldn't rub them even if I wanted to. You are asking about an 87 though. Might be better to ask folks with that body style.
Old May 7, 2016 | 11:30 AM
fuzzybob's Avatar
fuzzybob
Yes, mine are 15x8
Old May 7, 2016 | 12:51 PM
mjr46's Avatar
mjr46
my rims are off an 87, the truck is a 77
Old May 7, 2016 | 02:54 PM
crazy96863's Avatar
crazy96863
Didn't catch that... So you will be fine. Even 35s only need a 1"-2" lift up front.
Old May 7, 2016 | 03:27 PM
hasteranger
These trucks are so old it's hard to tell what's stock and what's not and it depends on how they were used. They all sit at a different height just depending on how worn out they are. But if the 33's rub it won't be much work or money to put some leveling coils up front and have it fixed.
Old May 7, 2016 | 08:30 PM
mjr46's Avatar
mjr46
with 31's mine had plenty of room, I ordered these 588.00 for 4
Old May 7, 2016 | 08:58 PM
HIO Silver's Avatar
HIO Silver
BE AWARE.... NOT ALL TIRES ARE CREATED EQUAL!!!
though tires may be labeled the same size between brands, their physical dimensions will vary!!
