Resisters for gauges
Old Mar 1, 2016 | 03:08 PM
gogoat's Avatar
gogoat
Does anyone have any experience with using resisters so I can use my original 6 volt gauges with my converted 12 volt system on my 49 F1. Also my system was pos grd and I'm changing it to neg grd.
Old Mar 1, 2016 | 04:31 PM
jonf's Avatar
jonf
Resistors don't work and it doesn't make any difference whether positive or negative.
Oil pressure, temp, and gas gauge are electrical. You need a voltage regulator for your electrical gauges.
Old Mar 1, 2016 | 04:38 PM
pbsdaddy's Avatar
pbsdaddy
Commonly called reducers. They are available in many forms and styles. These are from Speedway.
Runtz 12 Volt to 6 Volt Reducers
Old Mar 1, 2016 | 06:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There are dozens of threads in the past on all the different types and how to wire them. Runtz are the most expensive and you need 3 of them.
An Advanced search on "Runtz 12v" gives:
https://www.ford-trucks.com/forums/1...olt-again.html
https://www.ford-trucks.com/forums/1...es-to-12v.html
https://www.ford-trucks.com/forums/1...eg-ground.html
https://www.ford-trucks.com/forums/1...f1-gauges.html
...and 70 more
fisherman_chuck
Aug 12, 2015 04:48 PM
Becauseican1
May 19, 2013 12:16 PM
cookieman69
May 31, 2010 06:59 PM
007bronco
Feb 2, 2008 06:02 PM
Ronin007
Modular V10 (6.8l)
Jan 2, 2007 12:01 PM
