Will airbags make the truck less "bouncy" under load?
2015 F350 CC LB FX4. I routinely haul 2-4k of cargo in the back of my truck for 375 mile jaunts.... I do this at least once a week. Most I've ever hauled in the bed was 5k and it rode better than it does with 2k in the bed.
The ride is awful and the bounciness and instability driving on uneven roads or corning at speed is starting to really annoy me. Would a set of good airbags cure this problem? Hit a pot hole while corning on the highway around 60-70mph and you better hang on... feels like the back end is going to jump off the ground.
On my last trip down it was so bad I actually pulled off the side of the highway to see if one of my rear springs was broken.
... and yes... the cargo is evenly distributed under my truck ARE canopy. E rated tires set at 80 PSI rear, 65 PSI front.
To answer you question, yes. BUT, first thing I would do is change the shocks!!! These "Rancho" shocks are nothing but painted Ford shocks and are terrible. I believe a good set of shocks will cure your problem. However, that being said, airbags will help keep the truck sitting up and level. They will keep the truck from bouncing so hard on and off of the overload springs and deliver a more "even" ride. First and foremost I believe it is a shock problem. Start with that before trying bags. I carry 3200 pounds of pin weight in the bed of my dually most of the time. It's a decent ride, but I use bags to level the truck out as we all know Fords love to squat. Plus they really helps on interstate bridge expansion joints. IF you go with bags, you'll find you need an onboard compressor to change the pressures in the bags when loaded vs unloaded for a decent ride.
...The ride is awful and the bounciness and instability driving on uneven roads or corning at speed is starting to really annoy me. Would a set of good airbags cure this problem? Hit a pot hole while corning on the highway around 60-70mph and you better hang on... feels like the back end is going to jump off the ground.
Yes I think you would be very happy with improvement from bags. An in-cab pressure controller would also help as you can adjust as you drive for different loads/roads.
If your load is up high a large sway bar is a better place to start.
Don't know if you have rear sway bar now, but I went with a Hellwig "Bigwig" sway bar on the second hole. That and some Bilstien 4600's changed my 350 noticeably. Definitely worth the money.
I went with real Rancho shocks to replace the fake FX4 Ranchos. RS9000XL shocks all around. I like the adjustability. Watch for deals or rebates from Rancho. I got them thru Rock Auto, with a discount coupon and Rancho was running a buy 3 get 1 free deal.
I also have airbags, but prior to changing shocks, they made bounce worse when towing my 5th wheel. The shocks slowed the up and down dynamic bounce.
Another thing I added and would HIGHLY recommend (maybe instead of air bags) is a set of TorkLift StableLoads.
They make the overload leafs start working sooner. They work. WELL!
I caught them on sale for just over $200 a while back. Looks like they went up to around $280 now -
They work as advertised, are cheaper than an air system, and don't allow the truck to sag. When you're empty your trucks suspension works as it does now, but when loaded you ride on the rubber "spring" and no bouncing or rear end sag. I've used them for ten years on several different trucks.
