Hi, I recently bought a 2013 F-250 and the fuel economy I was getting without towing was around 14 mpg. I have been towing a 6000 lb load and the dash computer says I should be getting like 9.4 mpg, however, I'm calculating like 7 mpg. I did overfill my fuel tank a couple of times. Could this have caused a leak or damaged something? My 2006 f-250 Powerstroke was getting like 9 mpg and I'm concerned.
Tire size will also affect your mpg.
My 2011 with the OEM 275/65R20s got 2 mpg better than my 2015 with 295/65R20 tires. Both trucks configured the same except for tires.
If I am lucky in the winter I get 13.5 MPG unloaded. In the summer 16 with my 2015... Add about 2 mpg for my previous 2011 6.7... I think it's the increased HP/TQ of the 2015 vs. 2011 that is main difference.
LoueyK - I doubt you could mess something up by overfilling a diesel. But checking underneath can't ever hurt to make sure you are not spewing fuel out. It sounds a little low to me. When I had really low MPG unloaded I was stuck in a regen. Only way I knew was because of the distinct smell. Other things to check would be a stuck brake caliper or being stuck in 4WD or even hubs locked can take some MPGs...
I got 10.2 per gallon going 55 miles an hour to the coast. Lot's of up and down and 15 mile an hour turns. I love the power and for the first time in my life I can use cruise control!
If you can stand it, try driving 50-55 mph for extended periods of time while unloaded.
Make sure your hubs are unlocked (in auto position) and the tires are inflated to t least 70psi. Accelerate as quickly as you can from a stop to 50, then drive with the lightest foot possible. This should get you 16-18mpg with summer fuel, assuming it's non bio blend.
Towing, winter fuel, and any wind will all hurt the mileage and if any of these 3 conditions are present you will see 11 or less easily. I find that winds and trailers are the main fuel enemies. I have a short trailer (approx. 8' tall) and I average 11-12mpg with it. I also have a 10' tall trailer and I average 9 with it.
I tow a 16,000 pound fifth wheel camper that has a bridge clearance height of 13'5". I get anywhere between 8 and 10 MPG when towing depending on fuel, wind, terrain, speed, etc. I usually tow at 65 MPH. I've seen my MPG's increase almost 1 MPG after filling up with quality fuel. We just got back from a trip to the east and were bucking a 15MPH head wind through Mississippi. My mileage dropped to 7.4 MPG.
However, no matter how you slice and dice the data, this is an awesome truck!
Towing a 9000 lb travel trailer usually at 65 mph 11-12 mpg.
Multiple unloaded short trips near home about 17 mpg.
Unloaded road trips at 65 mph 19-20 mpg. My best has been 21.3 mpg.
All mileages are calculated.
I get 21 mpg in cruise while going off a 6 mile high cliff if I don't touch the throttle on the way down.
I have a new 2016 F350 cc 4x4 Plat long box with 3900 miles on it.
The mileage numbers quoted are lower that what I have experienced in my truck. At 65 on flat highway , I usually run between 18 and as high as 23mpg on the dash . Strong winds have brought as low as 16.5.
Very happy with the truck and really contemplated going to the 6.2 gas.
Going to Alaska this summer!!!
