Fried GEN after gen light stayed on with key off
Popped the hood and the generator is sizzling. So is the regulator. Disconnected the battery as fast as possible. So...
I understand a bad voltage regulator will cause battery current to short back through the generator with the key off. This volt reg is new...the guy I bought the truck from 2 weeks ago rebuilt the motor and replaced it. I'm thinking if he wired it wrong I never would have made it 200 miles home.
I'm going to start tomorrow by popping the top off the voltage reg and see if it's fried. Not sure if the generator was ruined or not.
And ideas on what could have caused it other than a failed voltage regulator?
Generators don't charge at low RPM, so to prevent battery backfeed into the generator itself the relay (is supposed) to disconnect the generator completely at idle and on shutdown. You could try cleaning up the point surfaces on the cutout relay with a file. I never had any luck with that. If the cutout relay points stick, then the pole shoes (the field iirc) can get roasted. If you see dents on the top of a generator voltage regulator, this is why, one way to get them unstuck. Banging on the regulator.
What brand of regulator is installed? Like everything else these days, overseas replacements are not specifically too good. If you're going to run a generator, use only a quality old school back in the day regulator. NAPA has a rebuilt (generator) @ $45, it's probably not a bad plan to replace them after letting the magic smoke out. It's always good practice to couple a new generator along with with a new regulator. But not a cheapie. I bought an NOS Motorcraft for about $70 from that place down in Waxahachie and it works great. Electric motor shops used to be able to tweak the regulator to a specific generator, if there's an old school shop still open in your area that would be worth doing. The generators actually run a little hotter than an alternator, according to the manual:
It has "made in USA" stamped on the bottom, but no manufacturer like "Motorcraft", "fomoco", etc.
Wires from regulator to generator look OK, no visible heat damage.
The regulator was hot, but the generator was smoking.
Will pull the generator tomorrow and see how it looks inside. This may be a good time to convert to an alternator set up...
It would be interesting to know what might be the leading cause(s) for cutout relay sticking. I agree it doesn't seem likely to make two hundred miles if there were major issues.
At least that would stop the frying generator until a 1/2" wrench could be found to remove the battery cable...
12V across the battery posts with the truck running seemed pretty puny, so I ran a few tests, but I'm still not sure.
First test: Run the generator like a motor.
Procedure:
1) Disconnected the field and output/armature wires off the generator (left the ground in place)
2) Put a jumper on the generator between the field post and the output/armature post.
3) Loosened the generator mount and slipped the belt off.
4) Ran a jump wire from the "+" post of the battery to the output/armature post on the generator.
5) Verified that it spun. It spun. Not fast, but it spun.
Second test: Run the generator without regulation and test output.
Procedure:
1) Reconnected the belt
2) Left the jumper wire on the generator between the field post and output/armature post. Left the field and output/armature wires that run to the voltage regulator disconnected.
3) Started the truck and checked voltage from that jumper wire to ground. It read over 25V.
Both those tests made me start to feel better, but then the last test was a head scratcher.
After hooking everything back up, I fired up the truck and tried out the new battery cutoff switch, expecting the truck to keep running with the battery out of the loop. It died immediately. I ran up the RPM's over 2,000 and again it died immediately. Tried it again by disconnecting the negative terminal, died again.
So any ideas? Does this sound like the generator is wounded but not quite dead? Any other test ideas?
Just for grins you should try polarizing the generator. It's not "supposed" to be necessary unless generator has been disassembled or sat for a long time. Maybe motoring the generator accomplishes this? I dunno.
On Fords, with engine OFF disconnect FLD and BAT terminals at the regulator and briefly touch them together. May see a spark, that's fine.
When I was young and didn't have any money, I always first tried to fix something that didn't work. A lot of times it turned out, not always but often enough, a poor electrical connection was the cause. Simply removing and reinstalling something was enough to get things going again! That simple fact has served me well over the years. People lose their troubleshooting edge when spending other people's money, I'm convinced ha ha
I'm thinking the generator cooked a little too much when the cutout relay stuck last night. It sort of works now, but probably not well enough. Why did it stick? No idea...the voltage reg looked perfect on the inside. Poor grounds could have easily played a role. I'll address that with the fix.
If the gen is fried it's probably time to cut bait and just switch to an alternator. Looks like the Delco 10si alternator with an integrated volt reg is cheap and effective Total package is under $50 with a core. I found a homemade Y-block bracket design online. Looks pretty simple....just a long 7/16 threaded rod, nuts, washers, and some 3/16" x 1" flat stock.
Wish me luck...
Keep in mind if you do this though, that while any alternator available today will have far more current capability than a 30 amp generator, the trucks wiring harness itself does not. Maybe there is some overhead but I doubt it. So be careful not to exceed whatever was running clean as OEM.
Consider Ignition draws around 10 amps, the heater motor around 5, the lights all around probably around 12 or so. See where I'm goin' with that? Like I mentioned I was stubborn enough to make the obsolete tech work, learn the mysteries and rituals. It's rough out there these days - all the graybeards are about done and to most other people "generator" means a Yamaha. Thankfully there are sites like FTE and such. A Motors manual, the Ford Shop manuals are essential.
I'm going to buy an ammeter today and do that test before I pull the gen. I'm also a bit nostalgic about holding onto old tech as long as it works. I wasn't going to go nuts with the replacement alternator...just a basic one with 50-60 amps capacity.
This diagram came up using a google search, but I'm puzzled a bit by how they show the battery charging circuit, coming off the B tab of the volt reg, through the light switch, through the GEN bulb (!), and then, finally, to the + side of the solenoid and the battery. So if the GEN light burns out, you stop charging the battery? That can't be right...
F100 wiring diagram, but with errors?
