1964 F600 14ft flatbed dually
Old Feb 5, 2016 | 01:54 AM
ssyeller's Avatar
ssyeller
Not sure of the motor yet picking up Sunday 2 7 16.
Vin F60AR520467 4spd. Pictures when I pickup.
Old Feb 5, 2016 | 02:28 AM
ssyeller's Avatar
ssyeller
What does this vin number mean for a motor.
thanks I have not seen an A designation before. any ideas.
Old Feb 5, 2016 | 06:28 AM
crazed87bronco's Avatar
crazed87bronco
Looking forward to seeing pics of the truck. I'm a fan of the big F series.
Old Feb 5, 2016 | 06:08 PM
ssyeller's Avatar
ssyeller
evidently it was a government truck
174 F602 181 N 64
GVW 20,000 160 3800 830177
I know have the truck will have some pics up soon
Old Feb 5, 2016 | 08:22 PM
fivestarmmd's Avatar
fivestarmmd
Has 330 md engine 174 wheelbase It was special ordered missing color code. cant cipher trans and axle codes. not enough charaters.
Old Feb 7, 2016 | 03:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ssyeller
VIN: F60AR520467
WARRANTY PLATE: WB: 174 / COLOR: BLANK / MODEL: F602 / BODY: 181 / TRANS: N / AXLE: 64 / MAX GVW LBS: 20,000 / CERT NET HP: 160 / RPM: 3800 / DSO: 830177
F60 = F600.
A = 330 2V Medium Duty FT Engine (A used 1964/65 only, C used 1966/78).
R = San Jose CA Assembly Plant.
520467 = 1964, assembled March 1964.
174" Wheelbase.
COLOR: Blank (Domestic Special Order paint color).
MODEL F602 = F600 .. 20,000 lbs. GVWR
BODY 181: 1 = Silver Gray Crush Vinyl & Light Gray Rib Vinyl / 81 = 81A Standard Cab.
TRANS N = New Process 435 4 Speed Manual Transmission (N used 1964/65 only, A used 1966/79).
AXLE 64 = Timken model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
830177: 83 = Sold to the US Government / 0177 = Domestic Special Order number, truck special ordered, not "bought off the lot."
Old Mar 2, 2016 | 09:40 PM
ssyeller's Avatar
ssyeller
build update
Tracked down Dewey brake booster exchange portland oregon rebuilt the brake booster for 160.00 It was a midland 11 1/2 in booster. Master cyc. was a casting 30031 which I almost sent to apple hydraulics in new york to rebuild but found one on the shelf at brake systems in Portland oregon for 187.00 Install and see what we have 3/3/16 after install.
Powder coated the booster housing safety yellow. Looking for 2 front drive tires 22.5 tubless tires. Other wise 300.00 ea or so.
anybody know if you can turn the front wheels around to put the tires further apart for a better look.
yargnitram
Dec 18, 2018 09:58 PM
hixbeme
Nov 4, 2008 10:38 PM
Black MI
Aug 24, 2008 08:15 AM
ibf250
Sep 27, 2004 10:00 PM
offorad2002
1983 - 2012 Ranger & B-Series
Feb 20, 2003 07:38 PM
