I have the same truck and that is where I got mine. I did have to call because it was not on there website. I bought the stainless set and it was generic for single, crew and super cab; it had different extensions for each.
Why not just bend new ones. It will give you the opportunity/excuse to buy some new tools! A flaring tool and a tube bender. Take your time they can look factory. You can even flare stainless with the right flaring tool. Just a thought I'm sure you thought of already.
+1 I'd do that before considering buying steel lines for 180 bucks, and being pre bent isn't any kinda of bonus at that price.
You can buy steel lines cheap at the auto parts bend them to fit or better yet either Nickel/Copper for around 50 bucks for 25 feet or Poly Amour for around half of that.
Both of those are corrosion resistant, both are easily bent by hand and resist kinking, couple features plain steel doesn't offer.
Buying two rolls of either one leaves plenty of money left over for a 3/16" tubing bender can be had for around 25 bucks, a double flare tool 25 bucks, "cheap" tools yea but how often will you actually use them.
I have a couple tubing benders but rarely use em I just use my hands. For the strain relief at the master I just spin the section of line around a hand held LP torch tank to create those coils, works great and looks factory.
Then you're left with a few fittings to complete the job, the fittings on the truck might be in good shape and are reusable. They don't tend to corrode away like the steel lines do, if not reusable or simply don't want too they are not expensive at your local auto parts.
I am thinking the same thing about buying new. I think I got away for less than $100 for custom lines, steel braided
Just did the rear line on the '87 and it was far easier than I thought it would be. For less than $50 I have the firmest brake pedal I've ever had on the truck.
That is a large cost factor. Because of the size of the box they come in shipping will be expensive. My first car restoration was my first and last try for prebent lines. The UPS guys reshaped the lines for me. I had to rebend them to fit!
