Custom IH intake spider/engine badge
Old Jan 25, 2016 | 05:24 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Recently I spent a lot of time giving my truck some much needed attention and it has shown in many ways. Although, 99% of that was mechanical and unless I painted or replaced the part the only time you know anything was changed is when driving it.
One of the more cosmetic things I did was remove the red/green vacuum lines and the wastegate solenoid in the engine bay which was mounted to the spider because I installed a Turbo Master wastegate controller from Diesel Site. The lines and solenoid were no longer needed and only added clutter in my opinion.
Well, that left a spot roughly 2x2 on the very front of the spider that I was not happy with because it just looked out of place and blank. I set out to find a fix for it and today I have completed the fix.
I bought a large IH pin that fits perfectly in that spot. Then I glued it on with some epoxy and called it a day.
Top picture is before, the two pictures below it are after. I am very happy with the results as it adds some contrast, color and finishes off what i did up there nicely.
Old Jan 25, 2016 | 05:42 PM
z31freakify's Avatar
z31freakify
Good job
takes the holes out of the picture nicely.
Old Jan 25, 2016 | 06:55 PM
mecdac's Avatar
mecdac
Nice work.
Old Jul 9, 2017 | 12:56 PM
ExPACamper's Avatar
ExPACamper
Sous- What did you use to plug the hole in the intake tube, where the Green line goes?
Old Jul 9, 2017 | 01:24 PM
Sous's Avatar
Sous
FTE Emeritus
A plastic plug that fit well with some black RTV around it for extra insurance.
Old Jul 9, 2017 | 01:57 PM
ExPACamper's Avatar
ExPACamper
Okay, thanks.
Sous
43
Mar 12, 2019 05:38 PM
2horses
6.7L Power Stroke Diesel
84
Apr 20, 2016 09:27 PM
PharmerChris
Oct 18, 2014 10:50 PM
385seriesHemi
Oct 29, 2013 05:10 AM
WA.Ranger
23
Sep 29, 2011 01:44 PM
