2015 EGR Delete kit/EGT Probe...
Old Jan 14, 2016 | 08:26 PM
FrontLineTrainer's Avatar
FrontLineTrainer
any recommendations on EGR delete kit...and are should I get kit that allows use of factory Probe or aftermarket? I see where factory probe plugs into DPF but not sure how that works then if moved to the egr block off plate? If using an SCT tuner or aftermarket gauge would I want the stock probe or aftermarket? Thanks all!
Old Jan 14, 2016 | 09:52 PM
RigTrash601's Avatar
RigTrash601
IIRC, with a 2015 Powerstroke, you are limited to the SCT tuners (SCTX4 & Livewire) so, you'll need the aftermarket probe for your Edge CTS (if you're running that) or for the SCT Livewire. No Limit Fabrication makes the plates on their delete kits that will accept either the OE probe or the aftermarket probe. The H&S tuners work with factory probe, but I don't think they're able to tune a 2015.
Old Jan 15, 2016 | 05:37 AM
FrontLineTrainer
Yes, I found when u delete DPF ect factory probe is then disabled so I will need to buy SCT's probe to use with my X4.
Kenny67
May 19, 2019 09:07 PM
Dave Dirsa
6.4L Power Stroke Diesel
Dec 16, 2015 09:08 PM
08F250SD_Laredo
May 4, 2014 02:52 PM
Regulator1988
Apr 10, 2012 08:18 PM
xpetom
Nov 14, 2010 11:17 AM
