Whistling when heating/AC fan is on high
Old Jan 9, 2016 | 06:42 PM
CtrlFreek's Avatar
CtrlFreek
Hi everyone,
I recently purchased a used 2014 F150 XLT, it has 18k miles. I found that when I turn the AC or heat fan is on high there is a loud whistling noise. However, I discovered that when the recirculate function is on the whistling stops. I took the truck to a Ford dealer since it's under warranty and they have replaced the blower motor twice but that hasn't fixed it. I can't help but think that the air intake to the vent system might be obstructed, that would explain why it doesn't whistle when recirculate is on. Has anyone else had an issue like this or know where they intake for the vent is?
Thanks in advance for your help!
Old Jan 10, 2016 | 10:22 AM
brokenleg's Avatar
brokenleg
sounds like one of the blend doors is causing the air to whistle past it.
Old Jan 11, 2016 | 02:47 PM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by CtrlFreek
Hi everyone,
I recently purchased a used 2014 F150 XLT, it has 18k miles. I found that when I turn the AC or heat fan is on high there is a loud whistling noise. However, I discovered that when the recirculate function is on the whistling stops. I took the truck to a Ford dealer since it's under warranty and they have replaced the blower motor twice but that hasn't fixed it. I can't help but think that the air intake to the vent system might be obstructed, that would explain why it doesn't whistle when recirculate is on...
Welcome to the forum, CtrlFreek. Let's get this escalated to your regional customer service manager. Since you're a new member, you may not have access to PMs yet. If that's the case, send an email to custserv@ford.com with your full name, best daytime phone number, VIN, current mileage, and servicing dealership. This email address isn't monitored, so put my name ("Crystal") in the subject line and post here once you've sent it. That's how I'll know to go and look for your message.
Crystal
Old Jan 11, 2023 | 01:11 AM
ford usr's Avatar
ford usr
2nd Gear
2011 F150
Hi everyone,
I have had this same problem as well. We took out the fan, cleaned it, sprayed where it was whistling, solved the problem. No need to have motor replaced
F150time
2009 - 2014 F150
Nov 4, 2019 10:15 PM
MikeRizz
6.4L Power Stroke Diesel
Jul 10, 2014 08:47 PM
bigtexan99
May 6, 2012 10:24 PM
bass-n-fire
13
Aug 3, 2011 08:24 PM
dirtduck48
Jun 17, 2010 01:30 PM
