Iowa Chapter Join Chapter, Leader:
Anyone near Cedar Rapids?
Old Sep 25, 2015 | 10:31 AM
William Mark Brown's Avatar
William Mark Brown
I recently bought a 1999 F250 XLT crew cab 7.3 PSD I have a few issues with it and not sure I can tackle all the issues on my own. It's too big to fit in my heated garage and "Winter is coming". I bought this to haul my new fifth wheel camper but so far the truck has just been problems.
Oil leak (HPOP resealed but something still leaks on top)
tranny leak due to over heating going up hill at Sugar Bottom. Need 6.0 cooler
Low power under load (maybe related to oil leak)
EBP sensor (cleaned tube, replaced sensor still reads wrong)
Rebuilt fuel bowl
Any known and trusted mechanics near me or someone willing to "lend a hand" locally? Even if it's just to chit chat and maybe give me help/advice.
Will
Old Sep 25, 2015 | 10:43 AM
Tedster9's Avatar
Tedster9
Sorry Will I don't speak Diesel, am here in Waterloo/Cedar Falls area. Maybe if you post in the Iowa chapter can get some help there if necessary. Let me know if I can too.
Old Sep 25, 2015 | 10:48 AM
monsterbaby's Avatar
monsterbaby
check the high pressure oil lines from the HPOP to the heads. mine rubbed through and started leaking. finally blew a hole in it and dumped a lot of oil in a hurry.
Also I think black widow diesel is in cedar rapids.
Old Sep 25, 2015 | 11:25 AM
William Mark Brown
I am trying to get an inspection camera. I think the HPOP reservoir seal on the bottom might be leaking but can't see under it. The hoses look newer and seem to be the braided stainless steel?
I've heard good things about Black Magic diesel but not Black Widow.
Old Sep 29, 2015 | 11:34 PM
cjgray1974's Avatar
cjgray1974
Rebuilt fuel bowl
Will
How bad is the oil leak? the turbo pedestal is known to leak at the exhaust back pressure valve.
Low power could be a boost leak among many other things. You can make a pressure tester out of pvc, I'll try to post a pic.
whats your EBP reading?
You would get more help if you posted in the 7.3 section.
Old Sep 30, 2015 | 06:50 AM
fellro86's Avatar
fellro86
It is Black Magic diesel over in Hiawatha. ATC just west of Tractor Supply is another for stock repairs.
I work over on the SW corner almost out to Wholesale Tire.
Old Sep 30, 2015 | 07:43 AM
William Mark Brown
I'm in that thread. I was just trying to find someone local that knows about these trucks and engines. This is my first big diesel truck and no clue of what's good or not. I'm learning but it's slow.
I just replaced the EBP sensor and now EBP and Baro are reading within .5 of each other which is good. I don't recall the readings right off hand.
Old Sep 30, 2015 | 07:44 AM
William Mark Brown
Nice! I live and work on the NE side.
patchychilli
44
Jun 7, 2017 07:02 PM
mlbbaseball
Mar 25, 2014 08:10 PM
Jesser02EX
19
Sep 11, 2013 12:37 PM
rich gill
Nov 19, 2008 08:08 PM
flamedoutf250
Indiana Chapter
Jan 25, 2008 08:53 PM
