Parking Brake Options
As many of us around here are fully aware, the stock parking brake leaves much to be desired, especially when they're wore out. I have seen a few different setups, and was wondering what I should go with. I am pretty attached to the original park brake handle, and would like to keep that if at all possible.
Rebuild original. Simple enough I think, but where would I even find parts to do this?
Go with a manual caliper and disc brake in stock location. I've seen this done, but can't seem to find any as I look now.. (I'm not great with the search feature on this forum)
Hook up the lever to the park brake cables in the Dana 60 I swapped in. I'm looking most seriously at this as a good difficulty/results option.
Anything different? I'm open to ideas!
I hooked Lokar cables and handle (between the seats) to my 8.8 rear end that has disc brakes and a drum EB on each wheel. Works great and I will have a center console with hinged access to the EB handle as another small theft deterrent. I liked the idea of having two cables that come to the middle for a simple hook up, so I removed the original EB lever.
[QUOTE=fladoodle;15585715
Anything different? I'm open to ideas![/QUOTE]
I've always liked the brake handle as they existed on these larger trucks. Something you can get your hand on and pull if necessary.
When I made the engine swap and auto transmission into my F4 I fabricated a bracket to hold the brake handle to the frame cross member. I used a brake cable from a later model F350 to connect my brake handle mechanism to the original brake cables of the Dana 70. Works great with plenty of force to lock the brakes.
I'll look for pictures.
tsevrens
31
02-07-2023 10:14 AM
LongRider
20
06-16-2018 02:18 AM
bagman1995
03-23-2018 06:58 PM
MikeGV
02-06-2005 09:43 PM
