Power Brakes and Steering?????
Old Aug 1, 2003 | 10:30 PM
Trader Bob's Avatar
Trader Bob
Question Power Brakes and Steering?????
I was wondering those who have installed the power booster kit how well it works. Did anybody have to add a electric vaccum pump? Are all the kits about the same or does anybody know which one is best to buy I hope to purchase one next month along with a front disk brake kit and reverse eye springs for the front and back. Then new smooth wheels, caps, beauty rings Anybody with the toyota power steering kit and what are your thoughts??? Thanks for all the help, Bob
Old Aug 4, 2003 | 11:29 AM
29abone's Avatar
29abone
Unhappy Power Brakes and Steering?????
Well TraderBob, I don't know what year truck you have, but I just ordered the v-shaped, bolt on Toyota bracket and pitman arm from MID-Fifty for my 56. I allready have the Toyota box and I'm going to install a tilt column at the same time. You can buy a kit to use the original steering column, but mine is screwed up. This seems to be the best way to add power steering to an F-1 or F-100
Old Aug 5, 2003 | 12:50 AM
Trader Bob's Avatar
Trader Bob
Hi 29abone, thanks for your reply, are you staying with the straight axel? Let know how your install goes, I hope to be doing mine next month and I plane to use my tock column. I have a 53 . Bob
Old Aug 5, 2003 | 07:13 AM
ddurant's Avatar
ddurant
Bob
i used a kit from these peple and i am very pleased with the results. i do not need a elec. vac. pump. the hookup to the carb. works great. it is a pain in the *** to get the bearing adapter on the orig. spindle. if you are interested i can tell you how i got it on.
http://www.classicperform.com/
Old Aug 5, 2003 | 09:39 AM
Trader Bob's Avatar
Trader Bob
Hi, thanks, all the help I can get would be great. I have not heard that there was a problem with the bearings-adapter. Good to hear the brakes work good for you. Bob
Old Aug 5, 2003 | 10:04 AM
ddurant's Avatar
ddurant
hi, Bob
they make a great kit, it has new bearings, races, even new dust caps. everthing bolts up. all the parts are first class. the bearing adapter is the only problem. i had to do the following to get it on.
1) use emery cloth on spindle to take it down so the adapter would almost go on (just about 1 inch wide at the back)
2) then i put ice bag on spindle
3) heated adapter in boling water
4) use 1 1/4 pvc pipe to drive it on
was not that hard it just took more time.
if i can help email me
good luck, you will love the way it stops
Old Aug 5, 2003 | 07:29 PM
Trader Bob's Avatar
Trader Bob
Thanks Dale, I understand what you did. Bob
Old Sep 6, 2003 | 11:54 PM
Trader Bob's Avatar
Trader Bob
Hi Dale, I got my brakes on and the booster. All seems to work fine but my brake padal goes 2/3 rds of the way down before the brakes take hold, and the brake light goes on. I put a "T" in the line to the front for the brake switch. What did you do for a switch? I'm thinking I should go to a different switch so the brakes lights come on sooner than they are. ???? I have no problem stopping but not sure about the pedal going down so fare??? Bob
Old Sep 7, 2003 | 05:09 AM
Flat Ernie's Avatar
Flat Ernie
Trader Bob,
Not trying to insult your intelligence, but have to ask the obvious questions:
-Did you bleed the system well?
-If you changed the M/C, did you bench bleed that before installing?
-Check your brake pushrod length. The return spring may bring the pedal back up, but the pushrod might not be touching the M/C piston.
Old Sep 7, 2003 | 03:15 PM
Trader Bob's Avatar
Trader Bob
Hi Ernie, bench bleed m/c, and bleed the systom untill no air starting at the longest line, down to the shortest. My return spring is not on at this time, pedal retuns back up just fine. Will give the systom another bleeding and see what happens. Bob
Old Sep 7, 2003 | 05:29 PM
ddurant's Avatar
ddurant
trader bob
i had to bleed mine over and over again. is the boster under the floor. my kit came with a parporting value attached to the booster and the brake switch went on the value.
Old Sep 8, 2003 | 09:29 AM
tgregoire's Avatar
tgregoire
This maybe too simple but did you make sure the rear shoes are adjusted properly? Does the pedal get any better if you pump the brakes?
Just some thoughts.
Old Sep 8, 2003 | 11:38 PM
Trader Bob's Avatar
Trader Bob
Yes the booster is under the truck, I can pump the pedal and no change, and I did adjust the back brakes. I'll try more bleeding on Sat. thanks , Bob
Old Sep 9, 2003 | 01:24 PM
Earl's Avatar
Earl
Bob, if there is air in the system the pedal will be very soft. I don't mean it will go down two-thirds of the way before you get resistance, I mean the resistance will gradually build up over a lot of pedal travel. It sure is possible that air is the culprit, but I'm thinking you've got a linkage rod or something in the booster that isn't making contact until you move the pedal quite a ways. Just another thought.
Old Sep 9, 2003 | 08:56 PM
Trader Bob's Avatar
Trader Bob
Thanks George, I'll check the linkage and do more bleeding and let you know what happens. Bob
