Can't identify this vacuum line
Old Aug 2, 2015 | 09:15 PM
Presence's Avatar
Presence
Over the last couple of weeks, I have been having problems with my A/C (it works, but doesn't always blow out of the front vents though eventually it does) and have read several other threads here that all suggest checking vacuum lines.
So I popped the hood of my '06 Navigator and had a look around the areas people identify as problem areas, and sure enough here I find this line that is not connected... but I cannot figure out where it is supposed to go. It comes out of the firewall on the passenger side, and when I found it it was sitting alongside the A/C lines. Haven't a clue where it connects.
Can any of the knowledgeable people help me out here?
Old Aug 2, 2015 | 09:16 PM
Presence's Avatar
Presence
Sorry for the huge pictures, and they need to be rotated 90 degrees clockwise.
Old Aug 2, 2015 | 11:08 PM
Skauber's Avatar
Skauber
Coming out of the firewall;
There are only two vacuum hoses coming through the firewall. One for main vacuum supply for the entire HVAC, if this one is cut then the HVAC goes into defroster mode only and doesn't work. The other one is the vacuum line for the heater control valve sitting next to the airbox on passenger side. This one shuts off coolant flow to the heater core when in AC mode.
Another hose that goes into the firewall is the washer fluid hose for the rear washer, but it doesn't look like it's that from the pictures.
Old Aug 3, 2015 | 07:48 AM
Presence's Avatar
Presence
Ok, but my issue is I don't see where either connects. And I looked pretty thoroughly.
Old Aug 3, 2015 | 08:01 AM
Skauber's Avatar
Skauber
Check this one, not sure if the Navi has the same airbox as the Expy, but the heater control valve might be in the same place regardless. Nevermind the red scriblings, it was the best picture Google found for me..
The main vacuum supply is T'ed off from the vacuum line going to the 4WD solenoid on the firewall next to the battery.
Old Aug 3, 2015 | 10:08 AM
Presence's Avatar
Presence
You were correct - nothing was connected there, so I plugged it in there. That's the one that stops flow to the heater core?
Old Aug 3, 2015 | 10:12 AM
Skauber's Avatar
Skauber
That's correct. My '05 Expy had the same issue, it was not plugged in. I later discovered that mine was leaking when the vacuum pulled the lever back and closed the valve so I replaced it with a new one, 15 bucks for a genuine Motorcraft one from Rockauto, and about 5 minutes of my time. (tip: put some rags under it to catch any coolant when disconnecting it, if you will replace it in the future). To check the function, start the engine, set the AC to max cold and it should pull the lever back and shut off the coolant flow to the heater core.
Old May 20, 2016 | 10:34 PM
hchtx's Avatar
hchtx
so where does it go left or right by the ball
Help!!! Left stick? Or right ball???
Old May 20, 2016 | 10:42 PM
Action410's Avatar
Action410
It is difficult to understand your question. What stick or what ball?
>>>>>>>>Action
Old May 20, 2016 | 11:07 PM
hchtx's Avatar
hchtx
>>>>>>>>Action
I have the same problem I don't know where the vacuum line goes on the heater control valve on my 06 expy on the pic above with red letters which one do I plug the vacuum hose? On the stick looking thingh(left) or the right side in the middle of that cylinder valve?(right)
Old May 21, 2016 | 01:52 AM
Skauber's Avatar
Skauber
As I said when posting that picture, nevermind the red scribblings. I found that pic on Google, I'm not the one making that writing. The vacuum connects to the round piece, nothing is connected to the stick as it's the lever that the vacuum actuator (that round piece) pulls on.
Old May 21, 2016 | 02:13 AM
hchtx's Avatar
hchtx
roger that I appreciate your help i had to double check because the vacuum hose was attached to the clip on the edge (right of pic) the line was running perpendicular to the hood edge.....
Old May 21, 2016 | 10:28 AM
alloro's Avatar
alloro
The "left stick" is just that...a stick...a pivot point, it is not a vacuum port. The hose connects on the right end of the valve shown in that picture.
Old May 21, 2016 | 01:59 PM
Action410's Avatar
Action410
Ahhhh the stick and the ball. Not referring to a stick shift nor a ball joint.
Rather it is a vacuum valve that controls coolant flow into the heater core. When the HVAC system is set to cool that valve closes the majority of hot coolant flowing to the heater core. Having heated coolant in the HVAC system kind of defeats the mission of cooling.
With that vacuum hose disconnected not only does the HVAC system not cool as efficently the engine and the HVAC system has a vacuum leak. Connecting the hose as shown on this 2006 Lincoln Navigator fixes all issues.
>>>>>>>Action
Old Oct 16, 2017 | 04:52 AM
Aameiel's Avatar
Aameiel
I have a question about this.. I had to change the EGR and its tube when i noticed that on my heater core valve the vacuum line is broken as the line was just hanging there. What I would like to know is where does the other end go ? i can't seem to find where the other end goes. The line is plugged in at the valve and just hanging. TY in advance.
I have a 1997 Explorer 5.0L
electricman98
Jul 2, 2019 08:31 AM
fordtruckguy07
18
Sep 11, 2018 09:03 AM
jchosler
Jun 30, 2011 09:34 PM
1994 F250: 351, C6
Jan 20, 2009 01:14 AM
1973fordf-100
Sep 17, 2008 09:42 PM
