What Carb # Should I Have
Old Jul 31, 2003 | 04:31 PM
SENOJ36's Avatar
SENOJ36
WHAT CARB SHOULD BE ON A 76 TRUCK WITH A 390
Old Jul 31, 2003 | 10:41 PM
Caddy 53's Avatar
Caddy 53
I think that you probably have a 4 barrel carb and if so the factory carb is a Holley #4160 520 cfm.A 600cfm will also work. If you canget copy of Ford Shop Manuel it will give all settings,acc.pump set up along with jet size. That carb also used a 1" thick alum spacer under carb w/2 gaskets only aval.from Ford. The gasket has metal laminated in it.
caddy 53 chuck
Old Aug 1, 2003 | 12:01 AM
Ford_Six's Avatar
Ford_Six
Welcome to FTE!
PLEASE TURN OFF THE CAPS LOCK!
Is there a 2BBL or 4BBL on it now?
