Open or closed crankcase breather
Old Jul 31, 2003 | 11:26 AM
Redone's Avatar
Redone
I've got a '79 F150 w/ 351M and I'm looking at replacing the crankcase breather unit with something that will allow more outside air into the carburetor. I know the cooler the air the better, to a certain point.
Ideas? Facts?
-Chris
Old Jul 31, 2003 | 12:06 PM
johnsalterego's Avatar
johnsalterego
Usually the PCV valve draws the 'bad air' out of the motor - the only time the breather side will really allow any significant crankcase gasses into the air cleaner is a.) when your foot is on the floor and there isn't enough vacuum to run the PCV valve, or b.) the motor is worn out and has lots of blow by the PCV can't keep up with. I don't know that the slight difference the breather makes in intake temperature is worth the buildup of the combustion acids inside the block (not to mention the motor will stay cleaner on the outside if it's sucked into the motor instead of pucked out onto a valve cover). Just my opinion; I'm sure some of the 'every last pony' folks here will dissagree!
I don't know what state you live in; if your truck has to pass a visual emissions inspection that is one of the things they will look for. However if you keep the original setup laying around it's easy enough to swap back on just to get the sticker...
Old Jul 31, 2003 | 12:54 PM
bubbaf250's Avatar
bubbaf250
Relative to the air inhaled by the carb, crankcase breather output is insignificant (unless you have really horrible blowby). You can run an open crankcase breather if you really want to, but as John said, it is not emissions legal.
Another option to improve the engine's breathing potential some (though it probably wouldn't make a difference with a stock-ish 351M) is switching the air filter housing to the larger 460/HO unit. Overall diameter (17") is somewhat larger than stock, but it fits on the stock 2V carb and it retains all the OEM temp sensors and cold-air snorkel. The filter element for the 17" housing has about 30% more area than the element in the stock 351M/400 housing.
Redone's Avatar
Redone
Okay, what about closed or open air filter for the carburetor? When I say open I mean something like you would see at a show where the filter is visible.
-Chris
Nevermind...I posted this before I got Bubbas' reply notice.
Old Jul 31, 2003 | 02:09 PM
bubbaf250's Avatar
bubbaf250
Open air filters suck hot air from under the hood into the carb.
They're a great deal if you want to lose about 5-10 hp or so.
Old Jul 31, 2003 | 02:15 PM
Redone's Avatar
Redone
Okay, I guess I'll stay away from that idea. Thanks.
-Chris
Old Jul 31, 2003 | 02:19 PM
Redone's Avatar
Redone
Forgot to include this in my original post.
I'm looking for ways to increase my fuel economy without sacrificing a few HP. By-the-way, with a stock setup what should I be expecting?
-Chris
Old Aug 2, 2003 | 01:24 PM
LxMan1's Avatar
LxMan1
Get a K&N filter element for the stock air cleaner and install true dual exhaust. Headers are optional.
Jimmy
