1986 f150 460 c6 to 300 with m5od
Old Jun 14, 2015 | 02:13 PM
86f150lariat's Avatar
86f150lariat
Alright after finally putting the 460 in ny poor half ton im ready to yank it out. I have an efi 300 6 and mazdog tranny sitting behind the house that i thought would be a perfect swap. Anybody done this? The truck was originally 302 aod with fi then i converted it to the carbed 460. I want it to br a daily driver and prefer a standard.
Last edited by 86f150lariat; Jun 14, 2015 at 02:14 PM. Reason: i csnt spelk worth a damn
Old Jun 14, 2015 | 03:24 PM
Franklin2's Avatar
Franklin2
Same routine as putting in the 460. But you will need new frame motor mount perches to mount the 6. You will have to go to the junkyard to get them.
Different radiator, hoses, throttle cable, etc. I would convert the six to carb to make the wiring easier, but that's me. If you don't have the efi wiring and computer you will need that and the diagrams to make it all work with the efi.
Old Jun 14, 2015 | 03:27 PM
86f150lariat
Alright i have a complete 96 f150 with the 300 efi and mazda. Just swap all the mounts for engine and trans right? And the pedal assembly?
Old Jun 14, 2015 | 03:33 PM
Franklin2's Avatar
Franklin2
Pedal assembly won't fit, you need one from a 84-86 truck.
You will need to grind/drill the perches off the frame. Just making sure you realize these are not "motor mounts" but brackets on the frame. Some may be bolted on, some riveted.
What's wrong with the 96? It may be easier to use that if you want to keep the efi.
Old Jun 14, 2015 | 03:34 PM
Franklin2's Avatar
Franklin2
P.S. 96 won't have a spot for a speedo cable. If you have 4x4, you can use your old transfer case for the speedometer. Otherwise, you have a problem if you are 2wd.
Old Jun 14, 2015 | 04:04 PM
86f150lariat
And if i throw a carb and intake on it?
Old Jun 14, 2015 | 08:14 PM
Franklin2's Avatar
Franklin2
A carb won't help the speedometer problem. Around 1993 or so Ford went to a electronic speedo that gets a signal from the vehicle speed sensor.
You may want to do some web searching, if you have a 2wd there might be a possibility of getting the back half of a older M5OD and the proper speedo drive gear and swapping it onto your later tranny. I am not sure on this so check first.
ke5adb
Engine Swaps
Feb 9, 2009 04:35 PM
jafajunkie
Engine Swaps
Apr 20, 2006 06:57 PM
fordbeast_80
Oct 8, 2003 02:54 PM
splatracing
Nov 15, 2002 06:18 PM
plb_wizard
Jul 30, 2002 02:52 PM
