86 f250 460/C6
Old Jun 13, 2015 | 01:53 PM
crrnchris's Avatar
crrnchris
86 f250 460/C6
Hi guys, a little rusty. Doing my transmission filter and fluid. C6 Auto. Who ever did it last went crazy with orange rtv gasket cement. I thought the last time I did one I put the cork gasket on dry. I haven't done one in almost 10 years. Should I use any rtv sealant?
Old Jun 13, 2015 | 04:12 PM
ctubutis's Avatar
ctubutis
The only orange RTV I'm familiar with is marketed as sensor-safe; I like this stuff because it's easy to remove when later disassembling things but I generally don't use RTV for anything not involving water. For this gasket, I would use Permatex No. 2.
Gasket Sealants : Permatex® Form-A-Gasket® No. 2 Sealant
Old Jun 13, 2015 | 04:17 PM
Franklin2's Avatar
Franklin2
I would not use anything if you can get away with it. If you do use some, put a very small trail on the part and smear it flat with your finger. You don't want big pieces of rtv falling into the pan and clogging up the filter.
Sight down the pan with your eye when you have it off. If the holes have been bent by someone over-tightening the bolts, put the edge of the pan on a strong table and take a hammer and smack the holes down flat to try and even it back out.
Old Jun 13, 2015 | 04:30 PM
crrnchris's Avatar
crrnchris
thanks guys
Old Jun 13, 2015 | 06:17 PM
crrnchris's Avatar
crrnchris
one last thing. I also drained the tork converter. Is that plug tapered. I don't think I screw it in all the way? Just double checking.
Old Jun 13, 2015 | 06:35 PM
stuart1's Avatar
stuart1
Sealant or glue is not needed.
ANYWHERE.
The drain plug is tapered as in pipe thread.
Old Jun 13, 2015 | 07:06 PM
crrnchris's Avatar
crrnchris
awesome thank you
Old Jun 14, 2015 | 07:19 AM
rowdyredneck's Avatar
rowdyredneck
Using RTV defeats the purpose of the gasket IMO. I've been a mechanic for over 20 years and I see stuff coming in all the time where people insisted on coating the gaskets with RTV. Cork gaskets are designed to swell and expand when exposed to oil. I've also seen blind holes that were so packed full of RTV the pan bolts either stripped out or cracked the casting when they were tightened. About the only places I ever use it are on differential covers and to seal the corners on oil pans, intakes, and timing covers.
cabloom300
Nov 3, 2013 09:52 PM
Old Brown F250
Aug 19, 2012 01:21 PM
oldcoupe42
Mar 23, 2005 05:30 PM
pward76
Jan 8, 2003 11:22 AM
bulabula
Mar 17, 2002 10:02 PM
