Offroad & 4x4
Dana 60 spring plate compatability?
Old Apr 17, 2015 | 02:45 PM
SnuffthePunkz's Avatar
SnuffthePunkz
Hey just looking for some quick info. I wasn't quite sure where to post as my question kind of crosses a few generations, so I figured the Offroad guys would be more knowledgeable about SAS's.
I have a 1992 F-250HD, that I'm looking to swap a 88 Kingpin Dana 60 into. I'll likely be picking it up this weekend, sadly it does not come with the u-bolt brackets.
I've been reading and I'm told any from like (Fuzzy on start year) 86-97 will be a direct fit, and I'm coming up with nothing thus far. If I have to I'll notch the diff and flip the bolts, I would rather not though if can be helped. I've stumbled upon some 79 u-bolt brackets. They won't work will they? I believe the Leafs were a different diameter just my google-fu is failing me on this question.
Old Apr 17, 2015 | 06:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
not positive on that. if i remember correctly, the 79 used 2 1/2 inch springs compared to the 3 inch 86- 97 springs. they may still work though, i would try one if you can get it cheap enough.
Old Apr 17, 2015 | 09:29 PM
SnuffthePunkz
They are like $120 before shipping/duty. I crawled under my uncles truck and took some snap's of his Dana 60 bracket, and I think I'm out of luck on that front.
Here is a link to the 79's.
Ford Dana 60 Spring Plates | eBay
And my uncle's, without even measuring they look different, the 79 has a ridge that the 86-97 don't have.
Dana 60 Spring Perch - Album on Imgur
I believe I'm still on the hunt, thanks for the assistance.
Old Apr 18, 2015 | 04:30 AM
tjc transport
i ain't rite
yup, you are correct, no good. it has been at least 15 years since i messed with one, so i am a little rusty .
Old May 1, 2015 | 06:44 AM
JOHN2001's Avatar
JOHN2001
I came across this the other day. Good information BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Old May 11, 2015 | 10:39 PM
tecgod13's Avatar
tecgod13
Those look exactly like the ones I used on my truck when I did a SAS with a late 80's Dana 60. I think I remember that they were from a 79 or something like that as well.
While they are a little different than the later trucks, they worked fine on my truck. Perhaps asking the seller to measure them would be in order if you haven't gotten another solution by now.
Old May 25, 2015 | 10:30 AM
LeoJr's Avatar
LeoJr
Don't notch, drill a hole. Leave as much web matl there as you can.
fordatic
Mar 6, 2014 08:13 AM
snowfighter
Offroad & 4x4
Dec 6, 2010 05:14 PM
sparky69
May 2, 2006 02:32 PM
FordPickMeUp
Offroad & 4x4
Mar 15, 2005 04:15 PM
rancherman84
Jan 31, 2005 06:06 AM
