Preload Screw
Old Mar 16, 2015 | 10:35 PM
77_f250_custom's Avatar
77_f250_custom
Preload Screw
Hey fellas. On my 78 ford f100 2x4, where is the steering box preload screw located? Got a little walk in the steering.
Old Mar 18, 2015 | 12:23 AM
Jdeshler's Avatar
Jdeshler
The worm gear is on the top of the sector.. loosen the nut, take a screwdriver and tighten the worm gear (middle of the nut) then retighten the nut..
Good luck
Old Mar 18, 2015 | 07:51 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X on on right on top of the box only flat tip screw sticking up out of a lock nut.
For the steering - Start by adjusting the slack adjuster - it will be a locknut over what appears to be a bolt with a screwdriver slot. Put a screwdriver into the slot to hold it and back off the locknut. Slowly turn the screwdriver clockwise while rotating the steering shaft back and forth until there's very little to no play. Hold adjustment bolt and tighten the locknut. With power steering this is done with the engine running. Once the slack is adjusted out of the steering box, look at the top of the steering column (still under the hood) under the master cylinder. There's a heavy fiber washer (sometimes referred to as a rag joint) (1/2 ton only) that makes a coupling in the column, usually this is worn out and the cause for excessive steering play.
Steering adj #2 all you have to do is on the steering box you will see a threaded screw with a jamb nut keeping it locked down. put a screw driver on the screw and loosen the jamb nut, then with the jamb nut loose , tighten the screw till it stopes, then back off counter clockwise for one full turn, then holding the screw, lock down the jamb nut. take the truck for a ride and see how it feels, if it is still too sloppy, loosen the jamb nut and turn clockwise a quarter of a turn and retighten the jamb nut. if the steering is too hard or feels like its binding , hold the jamb nut and loosen the set screw a quarter of a turn from your initial setting.
Old Mar 18, 2015 | 09:11 AM
77_f250_custom
Thanks fellas! I'll be sure to try those out tomorrow. The rag joint appears to be allowing no play (tried grabbing above and below it and rotating opposite directions). However, if I grab the shaft just before the steering box, I can hear it rotating and I have a bit of play before the pitman arm starts to move. Slowly getting her ready to hit the road again!
Old Mar 18, 2015 | 09:12 AM
77_f250_custom
Also, 77&79F250, are both of those located on the steering box, or is one located somewhere else?
Old Mar 18, 2015 | 10:15 AM
Jdeshler's Avatar
Jdeshler
This is my 2wd 79.. The wrench is an 11/16th..
Old Mar 18, 2015 | 11:05 AM
77_f250_custom
You guys rock! Mine was so packed full of grease that I couldn't see the screw driver slot.
1989 4x4
Oct 30, 2018 09:01 AM
GroovChampion
May 21, 2017 09:32 AM
jgavac
Jan 13, 2015 10:24 PM
13MWZ
Dec 3, 2004 11:19 AM
ahawes
Aug 8, 2003 11:42 PM
