rear slider window...power? or not? no latch! power ?
So I just bought a 2004 f350 with a sliding rear window...but it has no latch on it. but it is 3 panels of glass back there..so how do I open it? my '99 f250 has a latch, grab it open and slide window open. This one, no latchy deal. I grab the middle glass panel and try and slide it and no deal, ain't moving. So if this thing is power where is the control for it? I have looked all opver the cab and cannot find anything.
I will hafta look again I guess...All I saw there was the 2 switches for the map lites and 1 rocker for the sunroof...maybe its "hidden" towards the front of it but I swear I didn't see it.
Maybe I looked harder at the dash area and not so hard on that overhead console.
Thanks, will investigate tonite and inform.
I have seen them there as well. Different trim levels located the switch in different locations.
You should also consider the possibility that it was installed post-factory, and that darn little switch could be anywhere. I saw one install where the switch was hidden under the dash by the ODBII port.
