1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Electronic 4x4 operation F350 2015
Old 03-02-2015, 01:03 PM
poulton's Avatar
poulton
poulton is offline
Need help understanding how the front axle works when you have electronic 4x4.
I understand the rear wheels will Lock when the switch on dash is turned but cant find info on what happens with the front axle.
What will front axle do in a case of the rear locked but say stuck in mud and no fwd progress being made. Will front pull you out?
Will front act as a old school limited slip?
Thanks in advance
Old 03-02-2015, 02:14 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
When you turn the dial to 4wd or 4low a electric motor turns the tcase lever, then a vacuum pump sucks vacuum so it automatically engages the front hubs.
Now when in 4wd the truck sends 100% power equally front to back and whatever tire spins will spin. If you have the rear elocker option and you engage it both rear tires spin together no matter what until 20mph then it disengages and will reengage below 20mph again. The front will spin the tire with the less traction because it is a open carrier
iPhone from IB AutoGroup
Old 03-02-2015, 02:40 PM
poulton's Avatar
poulton
poulton is offline
Thanks for the help
I asume one can add a after market limited slip in front so when hubs are activated it works like old scholl manual? Just activated electricaly
Cheers
Old 03-03-2015, 10:13 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
you can also manually lock the front hubs in(with the dial on the hubs) if you plan on doing heavy 4wheeling/plowing or if the auto feature fails because of a vacuum leak.
I'm not sure if anyone offers a LS or locker for the front axle of the newer super duties. If it was me I'd go with a selectable locker in the front over a limited slip, that way you could drive in 2wd with the hubs locked in and not get any steering issues like you would with a limited slip in the front.
Old 03-03-2015, 01:37 PM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
Spartan offers a drop in (lunchbox) style locker for the front D60 in our trucks. They run about $450 and take 2-3 hours to install. It'll definitely do it's part to get you out of the sloppy stuff.
Lockers for Dana 60 Front, Reverse Rotation Differentials
Old 03-04-2015, 11:16 AM
SuperDutyScaler
There are tons of front options for the Dana60 axle
sawtooth
03-15-2014 01:21 PM
fordman19762003
11-16-2013 08:24 PM
Cowpop
36
02-08-2010 12:34 PM
grey77
2004 - 2008 F150
03-03-2004 07:26 AM
bri
Offroad & 4x4
01-11-2004 11:11 PM
Quick Reply: Electronic 4x4 operation F350 2015
