93 f150 302 5.0 4x4 got some problems
Old Mar 1, 2015 | 07:58 PM
bryanrandall's Avatar
bryanrandall
New to the forum so not quite sure how this works bUT I have a 93 f150 302 5.0 it was shaking real bad around 1000 to 1500 rpm and would cut off while idiling changed spark plugs wires distributor cap rotor button iac valve and fuel filter now it idils pretry well and doesn't cut off but still runs rough around 30-45 mph around 1000-1500 rpm but if you stomp the Gas and it drops down a gear it runs pretty good but there's oil coming out the valve cover vent hose that goes to air filter I already changed the pcv any ideas ?
Old Mar 2, 2015 | 03:23 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site
Tony
Old Mar 2, 2015 | 08:43 PM
bryanrandall
So no ideas of what's wrong thanks for the support guys
Old Mar 3, 2015 | 09:06 AM
WoodBoss's Avatar
WoodBoss
This is really an introduction forum. You may want to post under the forum for your year truck. That is where the technical people visit. Good Luck with your issue. You can also search the forum with your symptom to get some information.
I did a search and found this thread:
https://www.ford-trucks.com/forums/1...he-airbox.html
Someone else most likely has had just about every problem before. Learn to use the search function especially if you need an answer fast. Good Luck.
Old Mar 3, 2015 | 09:36 AM
bryanrandall
Thank you like I mentioned I didn't really know how it worked thank you
Robinssm
Site Announcements
Dec 12, 2016 08:25 AM
1993fordf150
New Member Introductions
Nov 23, 2008 11:23 AM
TerryM
Sep 29, 2007 11:40 PM
mjg
Apr 29, 2007 09:23 AM
