How to reset the oil life
Old Jan 19, 2015 | 08:00 PM
Vicky Terry Smith's Avatar
Vicky Terry Smith
I change oil at 5,000 miles but did not reset the oil life. At 7,500 miles it's telling me to change oil. My question is how? The book says to press and release the setup button but for the life of me I can't find the setup button. Not planning to change oil again till 10,000 because we are using synthetic oil. Any help is appreciated. My pickup is a 2014 350. Thanks!
Old Jan 19, 2015 | 08:15 PM
gwcon's Avatar
gwcon
You have to go into the information menu and scroll to oil. Use the arrow key to get into the oil item and then hold down the OK button to reset the oil life.
Old Jan 19, 2015 | 09:00 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Depends on the trim level, lower trim levels don't have the fancy display that works like you describe.
Basic display, press setup button(left side steering wheel upper button) until you get to the oil life, then press and hold reset(left side steering wheel lower button) until it shows new.
Old Jan 19, 2015 | 09:27 PM
Vicky Terry Smith
When I go to information all it has is MyKey and under that is System Check and under that is 1 warning which I can't go to but I'm sure it's the change oil warning. When I go to the setup button and go to the top it goes to settings and that has driver assist under that is rear park brake and so on but no oil.
Old Jan 19, 2015 | 09:35 PM
Vicky Terry Smith
It is a 2014 Platinum F350.
Old Jan 20, 2015 | 12:39 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, then it is like gwcon said how to do it, it's in there.
Old Jan 20, 2015 | 02:32 AM
Dakster's Avatar
Dakster
Maybe you have a user key and not an Admin key?
Old Jan 20, 2015 | 02:35 AM
rollerstud98's Avatar
rollerstud98
Go to truck apps i believe it is in the menu. Think thats where it is in my dads truck but his is an '11 so it could very well be different.
Old Jan 20, 2015 | 10:26 AM
EO2SeaBee's Avatar
EO2SeaBee
Here you go from my sig truck:
Hope this helps.
Old Jan 20, 2015 | 09:21 PM
McFarlandkm's Avatar
McFarlandkm
On the same topic, it would be ill advised to wait that long to change the oil in these new diesels. Highly recommend changing when computer says to. To much risk in oil dilution, etc these days.
Sent from my SM-G900V using IB AutoGroup
Old Jan 20, 2015 | 09:27 PM
Brandon D's Avatar
Brandon D
Lead Foot User
I think you misread something. The OP changed oil well before the system advised them to do so which is the best thing to do to avoid oil dilution.
Old Jan 20, 2015 | 09:52 PM
McFarlandkm
I got that they changed it at 5k, but stated they weren't changing for 10k more due to synthetic oil. I might be misunderstanding that but think not
Old Jan 20, 2015 | 10:10 PM
Brandon D's Avatar
Brandon D
Lead Foot User
My understanding is that they changed it at 5k and then will change it again at 10k. So changes every 5k. But maybe I misunderstood.
Old Jan 20, 2015 | 10:22 PM
Iowa Ford's Avatar
Iowa Ford
Brandon, that's the way I got it too.
Doug, you are great for helping out with pics. Reps intended !
Old Jan 21, 2015 | 07:01 AM
EO2SeaBee's Avatar
EO2SeaBee
Glad to help. Haven't seen the OP since I posted the pics though, so maybe they figured it out without the pics.
