Alaska Chapter Join Chapter, Leader:
Winter tire pressure
Old Jan 9, 2015 | 11:39 AM
747mech's Avatar
747mech
I've heard it both ways. Lower your tire pressure for better traction on icy roads. Or, keep them at max to avoid flats in extra cold temps.
Opinions?
Old Oct 26, 2016 | 11:12 PM
ironbender's Avatar
ironbender
This time of year I inflate to max psi. pressure will drop as the temp drops.
IIRC, it's 1 psi for every 10*F. If you go to max psi, say 75 psi (fronts on my superduty), when the temp is 40* and the temp gets to -30* in the winter, there is a 70* temp diff which will be a 7 psi pressure drop.
My approach anyway.
Old Mar 8, 2018 | 12:36 PM
Tall Timbers's Avatar
Tall Timbers
I aim for normal inflation levels, but sometimes add a couple of PSI if colder weather is coming. I'm located in Fairbanks. I would think that the best traction would come when a tire is inflated to the recommended amount with load being considered.
Old Nov 17, 2020 | 10:16 AM
747mech's Avatar
747mech
Good info.
Old Nov 16, 2021 | 11:36 AM
TooCold's Avatar
TooCold
When I lived in Fairbanks I over inflated to avoid "square tires". I have seen tires come off the rims at 30 below. I now live in Anchorage and may add a lb or two but that's all.
DND58
All Things Towing
Apr 20, 2011 08:13 PM
ernesteugene
42
Dec 21, 2009 02:20 PM
someday
General Automotive Discussion
Oct 30, 2008 10:09 PM
hrsetrdr
1997 - 2003 F150
Jan 10, 2007 11:25 PM
crosbo
Sep 21, 2006 01:00 AM
